Front emergency brake cable adjustment
I bought a 92 4runner with no front parking brake, and I recently installed one. I bought it used, which was a mistake bur whatever, already here. I'm trying to make it work but it seems like the cable itself is too long. I can pull the handle all the way and the lever which controls the rear brakes under the cab barely moves at all, also there is some noticeable slack in the cable when it is not being pulled. Not sure what to do here.
If you had previously tried adjusting the e. brake by rotating the star at each rear wheel you’ll need to go and undo that. Back them way off. Then go to the bell crank and adjust. Once you have the parking brake tension set properly you can go to the rear wheels and make the final adjustment
Etype R
Nov 14, 2005 06:37 AM
