Front diff
Old Jun 15, 2011 | 10:31 AM
rattlewagon's Avatar
Bumpin' an old thread. This has happened to the ADD diff in my 87. The seal started dumping oil, so I went under to inspect and found a wicked wobbly shaft. The cause of this is bad bearing in the carrier correct?
Little bumed since I put that diff in 7 months ago, and would hate to have to pull it out again.
Old Mar 21, 2015 | 07:58 AM
Funksrunner's Avatar
Having a similar issue in my 94 4runner. I was getting a wicked rotational grinding and vibration in 2wd. Took it to a local Axle, Trans, transfer and gear specialty shop. They replaced the inner and outer wheel bearings on both sides up front, replaced what they said was a bent rear axle on the drivers side, and replaced a leaking rear pinion seal. I picked it up, drove 3/4 mile and low and behold ... the same vibration and grinding. Located some serious play in the passenger side output shaft on the front dif. I pulled the dif, front prop shaft, and both cv axles (which were replaced about a year and a half ago. No more grinding/vibration. I did notice a little brake wobble after the dif issue was removed. Going to tear into the dif today. I will update later (hopefully with pics) on what parts replacements wind up curing the ailment.
Old Aug 16, 2015 | 09:44 AM
warrenjcarlson's Avatar
That buzzing/ vibration is probably the needle bearings, I have a 1990 with ADD and pulled the diff to find gravely sounding needle bearings. Hope this helps. It might also fix your wiggling shafts.
jaretstuff
Aug 4, 2015 02:08 PM
yourrealdad
Jul 29, 2015 11:08 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
