Fried igniter?
Old Feb 7, 2014 | 05:07 PM
rj radar's Avatar
Same problem runs rich(i think) for 1-4 minutes then dies
Same problem runs rich(i think) for 1-4 minutes then dies. While my buddy and I were scratchin our heads after the truck started he touched a cluster of wires underneith the iac valve that looks to be coming from the vafm and it quickly died, maybe just a fluke? Need help i'm lost. Recent work done on vehicle:
Cleaned tb, and iac valve and new tb gasket, new thermostat, new engine coolant sensor, new ignition coil. What now??
Old Feb 7, 2014 | 05:08 PM
vulture2600's Avatar
check all your wiring!
Old Feb 7, 2014 | 05:13 PM
rj radar's Avatar
k I'll try. what wire did you bump out of curiousity?
Old Feb 7, 2014 | 06:54 PM
Topteke's Avatar
If the vafm is disconnected the vehicle will die immediately.
Old Feb 7, 2014 | 07:46 PM
  #25
i bumped a wire near the ignition key that powers the ECU.
Old Feb 8, 2014 | 04:24 PM
  #26
rj radar's Avatar
well, i should have mentioned I know jacksh&* about engine electrical, not only that dont have diagnostic tools to perform tests on anything. I'll buy what I can when I go parts store tomorrow but really don't know were to begin? any help?
Also forgot to mention when this started the other day I heard a clicking noise coming from the tps area, i think its the tps spazzing out not sure, this happened after the engine died like someone shut off the ignition. First time this happened I was driving hiway at 55mph, scary.
Also today I pulled a plug and there black as black gets, also there was some fluid in the throttle body when I pulled off the air intake.
one other thing it will only start if I push the pedal to the floor, and even then it idles for
about a minute then dies.
yea i'm lost.
thanks in advance.
Kamaloha
Oct 16, 2015 05:13 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
voiddweller
Sep 28, 2015 11:21 PM
tazman1972
11
Sep 28, 2015 10:32 PM
