Frame Rot Repair (Lots of Pics)
Old Feb 11, 2011 | 01:55 PM
  #41
Adk_Yota's Avatar
Did you use any rust converters or just the Marine Clean?
Old Feb 11, 2011 | 02:06 PM
  #42
fierohink's Avatar
Just Marine Clean. The POR 15 process is Marine Clean to remove any dirt, grime, and oil, Metal Prep and Ready to etch the metal, neutralize any remaining rust, and leave a zinc coating for the paint to bond with and then finally POR-15 epoxy paint which bonds with the metal.
Old Feb 12, 2011 | 12:57 AM
  #43
Cyberman's Avatar
Great work man. While you got the body off, you might as well use your brother some more and SAS that thing. Looking back, I should have gone that route when it was stripped bare.
Old Feb 12, 2011 | 05:15 AM
  #44
2+2=4Runner's Avatar
awesome job on the frame repair, wish i had the skills to do that on my truck!
Old Feb 12, 2011 | 05:47 AM
  #45
fierohink's Avatar
SAS, yeah... This was an unplanned catastrophe. It started out with cleaning the truck at christmas and finding out I had a death machine for a DD. There really wasn't any forethought on this just damage control. Plus I really don't do a whole lot of wheeling., many pulling a motocycle trailer and maybe driving through some fields. So I think down the road I may go with spacers and springs and a true-trac because I really haven't been limited by clearance just traction.
Old Feb 12, 2011 | 02:35 PM
  #46
Cyberman's Avatar
Come up with me to Rausch Creek sometime, then you might want to do that SAS.
I just picked up an 85 front housing, but it'll be a while for me.
Old Feb 12, 2011 | 02:48 PM
  #47
fierohink's Avatar
I've never been there. My neighbor used to go to a place called Paragon, I think, but I want to say it's not open anymore?? is this the same place?
And since you're close enough to invite me wheeling then that makes you close enough to invite to lift the cab back on, right?
Old Feb 12, 2011 | 02:51 PM
  #48
fierohink's Avatar
Well I got the first coat of POR-15 on
Old Feb 12, 2011 | 02:53 PM
  #49
fierohink's Avatar
And just as a reminder I started with this on the passenger's side:
and now have this:
Old Feb 12, 2011 | 02:55 PM
  #50
fierohink's Avatar
And this on the driver's side:
and now have this:
  #51
fierohink's Avatar
2nd coat tomorrow, and then if I can get some help the cab goes on.
Old Feb 14, 2011 | 05:48 PM
  #52
Cyberman's Avatar
Paragon is closed, Rausch Creek is a different place.
I've been where you are once. Ya gotta have a party and that cab will go right back on.
Old Feb 15, 2011 | 04:34 PM
  #53
fierohink's Avatar
Well I got two co-workers to stop by, probably the lat time they'll do that , and this is what happened:
Old Feb 15, 2011 | 04:36 PM
  #54
fierohink's Avatar
But before thy came over, I had to put my thinking cap on. How can I refill the trans and transfer case without standing there holding the bottles of gear lube?
Tada:
And that mechanics assistant didn't bother me or go on smoke breaks all day.
  #55
xxxtreme22r's Avatar
I think they walked of with some parts man, I doubt they will be back for more, they didn't leave much. hahaha.
Old Feb 15, 2011 | 04:37 PM
  #56
fierohink's Avatar
Now I just have a bunch of things to tighten down:
  #57
fierohink's Avatar
And talk myself out of a flatbed:
Old Feb 15, 2011 | 05:03 PM
  #58
mt_goat's Avatar
Good work!
Old Feb 15, 2011 | 05:58 PM
  #59
hillbillyjake's Avatar
nice work. getting ready to do this to my 86 very soon. were the outside frame rails not as bad as the inner?
Old Feb 15, 2011 | 07:30 PM
  #60
fierohink's Avatar
I only had a bad spot on the outside frame rail just behind the transfercase crossmember about the size of a fifty-cent-piece that needed patched. Everything else was on the inside frame rail, but it definately rots from the inside out.
