Frame Rot Repair (Lots of Pics)
Old Jan 26, 2011 | 07:04 AM
waskillywabbit's Avatar
I didn't take it as a knock, thus the smiley face.
You should really use valid contact info though in your order profile.
:wabbit2:
Old Jan 26, 2011 | 07:10 AM
fierohink's Avatar
:wabbit2:
Wait what?!?!
It looked good when i typed it in????
Old Jan 26, 2011 | 07:30 AM
flg8r22's Avatar
hats off to you man. you said from the start it could be fixed and we all thought it was junk. lookin great!
Old Jan 26, 2011 | 07:32 AM
Maybe it wasn't you yesterday. It was a LONG day and I didn't process anything when I got home last night. Shower then bed.
:wabbit2:
Old Jan 31, 2011 | 07:26 AM
  #25
fierohink's Avatar
While I'm waiting for my replacement hands fabricator (still sidelined with a broken wrist), I can start some side projects on the truck. Clutch kit, flywheel, slave and master cylinders have been replaced, thank you for 186k miles of service.
My Poly Urethane bushing kit has arrived:
So now I can prep the body mounts, spring hangers, sway bar links, I think the control arms will have to wait until warmer months when I can do this outside with some more space.
Old Feb 5, 2011 | 03:15 PM
  #26
fierohink's Avatar
Well I got an afternoon out of my welding hands (my brother) and got a lot accomplished.
Which sure beats the open hole I've had for the passed.... um I dunno a long time.
Old Feb 5, 2011 | 03:18 PM
  #27
fierohink's Avatar
He also got my spring hanger re-attached
I'm sure my ride will be improved over a free folating hanger.
Tomorrow the cross member should go back in. Then POR-15 and reassembly. I was shooting for 30 days for a turn around. I'm cutting it a little close. I think without a detour to an orthopedist I would have easily finished in a month.
Old Feb 5, 2011 | 03:36 PM
  #28
streetlancer's Avatar
Wow, Great work!
Now, did you treat the inside of the frame rails before welding on the patch?
Old Feb 5, 2011 | 04:42 PM
  #29
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
What inside of the frame rails? Have you been reading this thread? He didn't really have a frame behind the cab to begin with!
Old Feb 5, 2011 | 05:22 PM
  #30
I guess your right, Lol, there wasn't much left to begin with.
Old Feb 11, 2011 | 05:58 AM
  #31
fierohink's Avatar
So there was only a few things left on my punchlist before reassembly could begin. I needed to reattach the crossmember, patch a small hole near the transfer case crossmember, patch a small hole near the spare tire carrier, fab up a new o2 sensor perch, and replace my shackles that I had to torch off.
  #32
fierohink's Avatar
Well the UPS man brought my shackles.
I underestimated the HD quality of TrailGear parts. Apparently they have a different definition of stock replacement then I do.
Old Feb 11, 2011 | 06:00 AM
  #33
fierohink's Avatar
I made a "new", and I use that term loosely, o2 Sensor perch:
If you can see the gobs of weld, well thats what happens when you try to weld left handed.
Old Feb 11, 2011 | 06:01 AM
  #34
fierohink's Avatar
I got a crossmember reattached:
here is a better shot of my brother's purdy welds:
Old Feb 11, 2011 | 06:02 AM
  #35
fierohink's Avatar
He even threw in some extra protection for the spring hanger so I don't run into problems in the future.
I guess he thinks I'll have this truck for another 17 years to need frame repair again.
Old Feb 11, 2011 | 06:04 AM
  #36
fierohink's Avatar
And now I've started the process of the POR-15 application with a good cleaning of Marine Clean:
which washed off this:
For mostly new steel, there is a lot o dirt and grime that stuff takes off.
Old Feb 11, 2011 | 06:05 AM
  #37
fierohink's Avatar
And just for comparison, this is a piece of metal I cut out of the frame:
It is full factory thickness on the right of about 2.5mm steel and over time rust and rotted to nothing along the left side.
Old Feb 11, 2011 | 06:06 AM
  #38
fierohink's Avatar
And I replaced it with this:
I don't think I should have any structural issues
Old Feb 11, 2011 | 01:32 PM
  #39
fierohink's Avatar
So I mentioned before that the Marine Clean portion of the POR-15 process was done, and now so is the Metal Ready:
That whitish coating is a zinc plating/etching that allows the POR-15 to bind harder with the metal. Awesome.
  #40
fierohink's Avatar
Tomorrow is the big painting day. The rig might even see the light of day.
