Fluctuating Timing
Old Mar 12, 2009 | 06:35 PM
95RunnerSR5's Avatar
Fluctuating Timing
Ok so rack your brains with this one. I installed the timing belt as specified in the FSM, rotated the assembly 2 times and the marks lined up. rotated the assemply 2 more times and the marks lined up again. Well when i try to set the timing with the timing gun, the mark on the crank pulley fluctuates back and forth from 10*BTC to 5* or less. From what i understand this is not normal. Shouldnt the timing mark be at exactly 10* steady? Pretty much everything on this engine has been replaced. Help me out folks
Old Mar 12, 2009 | 06:43 PM
abecedarian's Avatar
do you have the jumper in the diagnostic plug?
Old Mar 12, 2009 | 06:49 PM
yes sir
Old Mar 12, 2009 | 07:00 PM
timing shouldn't be jumping around... but if the TPS is faulty or isn't adjusted properly that could happen.
Old Mar 12, 2009 | 07:08 PM
really? its probablly improperly adjusted. its only a few years old. how would it make the timing jump aorund?
Old Mar 12, 2009 | 07:13 PM
if the ecu doesn't get the IDL signal (saying the throttle is at fully closed) from the TPS it won't go into the proper mode to let you adjust the timing.
Old Mar 12, 2009 | 07:15 PM
makes sense. i'll give it a go tomorrow and get back to you
Old Mar 13, 2009 | 03:42 PM
alright well the tps is within specs. hmm? its goin to the dealership tuesday for the steerin relay rod recall so i'll have them check it out i guess
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
