Fixing highway shaking
Old Aug 8, 2017 | 08:45 AM
128keaton's Avatar
Originally Posted by maco35
And when you say rebuild the drive shaft you mean replace the u-joints? the price sounds fair since i paid the machine shop $40 to replace both front and rear u-joints on mine about 5 years ago, and i paid about $25 each at the parts store for the u-joints.
No, rebuild as in get a new shaft, spline, and yoke, weld the spine to the shaft, swap my u-joints and flanges, and be on my way.
The seal part # is 90311-38047 and the write up i used is 4crawlers, and when putting the stake nut back on i just tightened it a 1/4 of a turn extra to prevent vibration when letting go of gas pedal. http://www.4crawler.com/4x4/CheapTri...eal/index.html
Thank you!
I've contacted a buddy who works on frames--gonna see what he says.
Old Aug 8, 2017 | 12:26 PM
maco35's Avatar
Thank you!
Cool, that's a killer deal and hopefully that'll fix the problems you're having.
Old Aug 8, 2017 | 07:06 PM
128keaton's Avatar
It did not unfortunately. The more I toy with it and think about it, its almost like the front axles are engaged to the diff. Like 4WD is on without the t-case transferring power from the engine to the front diff.
Old Aug 8, 2017 | 07:41 PM
millball's Avatar
It's certainly easy enough to find out if that's the case. Raise the front end and turn the wheels.
Old Aug 9, 2017 | 05:47 AM
  #25
ewong's Avatar
I had a speed related vibration that drove me bonkers - kept thinking it was a bum U Joint; that I had mangled it beating the old u Joint out (my U-Joints are Spicer 1350, not Toyota - long story)
Anyway - it turned out to be..... a tire belt de-laminated and the tire was no longer "round" but egg shaped...
Old Aug 9, 2017 | 08:17 AM
  #26
coryc85's Avatar
I can't see if your truck has manual hubs or not. I would disconnect front driveshaft and see if the vibration goes away. That will help you narrow it down.
Old Aug 9, 2017 | 05:14 PM
  #27
128keaton's Avatar
Turned independently of each other-- but I heard an odd noise. Can anyone confirm that this is normal?
https://www.youtube.com/watch?v=srERapBjBUI&feature=youtu.be
ADD. This weekend I'm gonna try a couple of things. First, put all four corners up in the driveway (clear of course) and get it to vibration speed. Gonna drop the front DS like you said, I doubt its been greased. Then, I'm gonna pull the hub section that connects the CV's to the hub.
Old Aug 10, 2017 | 07:44 AM
  #28
128keaton's Avatar
I've ordered the rear pinion seal to replace so when I get it, I'll tighten the rear pinion bolt.
Old Aug 11, 2017 | 06:59 PM
  #29
captainslow's Avatar
How much wheel free play do you have? With the car off sit in the front and lightly turn it with a tape measure to see how far it goes each direction. Should be no more than 1" per FSM.
I had a vibration that just got fixed by adjusting the steering box. took slop out of the ride.
I know you say no free play in the ball joints, but it's pretty hard to wiggle it with your hands enough to know their condition. They are not too expensive if you get them as a kit.
  #30
lightly turn the steering wheel I mean
Old Aug 12, 2017 | 09:07 PM
  #31
128keaton's Avatar
I will take a look at that. frustrated coming off of a day of failure. Completely removed the diff to find it perfect as can be. Replaced the pinion seal. But no change.
Old Aug 14, 2017 | 10:12 AM
  #32
128keaton's Avatar
I'm taking it to an axle shop today. Even the new (er) axles were pulled from a wrecked runner. If it was spun and slid theres a chance of a bent axle flange. Looking at it on rear jackstands at speed really makes me think thats the problem.
Old Aug 15, 2017 | 09:09 AM
  #33
GrandPrix's Avatar
Check the spare tire. After years of banging around there might be a bit of slack in the cable. Found out after chasing all kinds of gremlins.
Old Aug 15, 2017 | 09:35 AM
  #34
128keaton's Avatar
Argh. So that $100 driveshaft is way out of true. fml. Lesson learned. I think there is something else beyond that since I still shake without it, just not as bad. Frustrating though. I'll resume investigation with a new driveshaft.
Old Aug 15, 2017 | 11:11 AM
  #35
ksti's Avatar
Thank you!
Did you take it to your frame buddy?
Old Aug 15, 2017 | 11:21 AM
  #36
128keaton's Avatar
wasn’t the frame
