Fixed rough idle on 22re!
Old Sep 12, 2007 | 02:35 PM
co4rnr's Avatar
My engine used to idle terribly. Today I replaced my thermostat and found that the wire going to the top of the temp sending unit on the t-stat was broke. I cut off the old connector and crimped on a female end instead and plugged it in. When I started my truck to check for leaks, I found that it idled much better. Just thought I would let you guys know in case you have the same problem.
Old Sep 12, 2007 | 02:42 PM
bretthayes's Avatar
Interesting.. I have an 85 4Runner and it idles fine, but every once in a while after its warmed up, i will get a quick drop in the rpm.. Not enough to stall the vehicle.. Kind of like a loose wire that's not connecting.. I've noticed my wiring is getting old.. Sound familiar or completely different?
Old Sep 12, 2007 | 03:05 PM
co4rnr's Avatar
Sounds about the same. The wire that was going to the top of the sensor was hanging on by one strand. I haven't driven mine around long enough to know if it won't drop back down.
Old Sep 12, 2007 | 05:45 PM
4runnerx3's Avatar
An automatic uses that temp sensor for overdrive. The one in green below goes to the computer for fuel ratio.
Old Sep 12, 2007 | 08:58 PM
longhungsilver's Avatar
OH MAN i can see every 22re owner on this forum clicking on this thread cuz of the title... LOL my 22re has a rough idle because it burns a substantial ammount of oil past the ring..
I find it funny that i clicked the link because i too, was like OMG a fix for my roughish idle!!!
Charecter1
Nov 6, 2023 10:08 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
