Fine tuning my 87 pickup
Old Nov 1, 2015 | 06:07 PM
Brandon H.'s Avatar
So I could use some advice finishing my truck before I get it on the road. It's a 87 with a Weber 32/36. Just cleaned the carb, new plugs and wires. I checked the timing with the advance hooked up and at idle it's at 12 degrees, didn't have vacuum plugs to check it unhooked I will check that this week.
I want a baseline for my jets, I want to be sure I don't run this truck too lean. Current it has
Idle Jet
P - 60
S - 50
Main Jet
P - 135
S - 140
Air Bleed Jet
P - 160
S - 165
Is this ok for Florida elevation? Should I go bigger? Need a baseline so I can fine tune when I start driving it.
Truck smokes a little blue when rev'd, plugged the pcv line and didn't help the smoke. Anything else or should I just assume it's blowby?
puddlepirate
Jul 30, 2016 06:29 PM
SoCal_Todd
Oct 29, 2015 05:52 PM
Draven023
11
Oct 1, 2015 06:47 PM
kawazx636
Sep 29, 2015 08:22 AM
charlie_fong
Sep 27, 2015 10:06 PM
