finally ordered my sas kit from trail gear
Old Apr 5, 2009 | 08:02 AM
934rnr's Avatar
Angle shims will help out your pinion angle too.
The 5" Sky-Jacker Soft ride springs I bought for my 82 had angle shims on it. It's a much cheaper way to do it.
Old Apr 5, 2009 | 08:06 AM
desert-rat660's Avatar
i just dont want the caster to change, i hate death wobble
Old Apr 5, 2009 | 08:36 AM
Blackulua's Avatar
Make sure you are running a high pinion diff or transfer case or both to have the front driveshaft workable.Otherwise shimming or removal of front leafs is what I did to mine.
Old Apr 5, 2009 | 01:59 PM
Matt16's Avatar
Is there really ay need for a solid front axle in Hawaii? I didn't see any boulder fields while I was there, just some dusty backroads that IFS would have done fine on. Where do you wheel in Hawaii?
By the way, that is a very clean looking setup there.
Old Apr 5, 2009 | 06:32 PM
  #25
Blackulua's Avatar
[QUOTE=Matt16;51108670]Is there really ay need for a solid front axle in Hawaii? I didn't see any boulder fields while I was there, just some dusty backroads that IFS would have done fine on. Where do you wheel in Hawaii?
here you need permission and a key to be invited and a str8 front Toyota to get there.
Old Apr 6, 2009 | 03:38 PM
  #26
just called trail gear i guess the brake hoses are on backorder, damn
Old Apr 7, 2009 | 11:41 AM
  #27
sav-yoda's Avatar
Well apparently they are out of alot of things, I am tryin to order my 3" sas kit and everyone in the country appears to be out of the 3" leafs, so I may have to go with the 4" as well. What size tire are you planning on running?
Old Apr 7, 2009 | 12:28 PM
  #28
91Toyota's Avatar
when this kind of stuff happens you need to relax and ride your dirt bike!
Old Apr 7, 2009 | 03:09 PM
  #29
i just got all my stuff in from trail gear except the hoses. im running 35" bfg baja ta's
Old Apr 7, 2009 | 03:21 PM
  #30
dropzone's Avatar
Fossilized
how did your shackle angles turn out, how did u mount the front spring hanger in relation to the front crossmember?
see post #5 for mounting your front hanger....
Old Apr 15, 2009 | 03:40 PM
  #31
007-4.jpg?t=1239838634
well i got all the welding finished on the axle. creeper gussets and armor. just need top find more time to install all this crap
Old May 29, 2009 | 06:54 PM
  #32
well guys i finally started on the sas swap. i got everything on the front end cut off thanks to the plasma cutter. i have most of the grinding done. im hoping to have it finished by tomorrow, sorry no pics i wasnt wasting any time on doing this.
if anyone local needs some ifs parts hit me up, soon...
Old May 29, 2009 | 06:59 PM
  #33
Justinlhc's Avatar
I tried to reply to your PM, but it wouldn't let me PM you? I might be interested in your CV's and possibly your front diff depending on gears and if it's locked or open?
Old May 29, 2009 | 09:55 PM
  #34
its an open front diff 4.10 gears
Old May 30, 2009 | 08:14 PM
  #35
the swap is finished besides some painting to do and a front drive shaft. got to drive it though. will have pics tomorrow
Old May 30, 2009 | 08:30 PM
  #36
poolskaterpt's Avatar
Speaking of Axles... I'm a new toyota guy, formerly 60's mopar street stuff. I'm pulling my hair out trying to put new CV's in my 94... if any of you guys know the little tricks that will make this easier it would be really appreciated, I'm in a wicked time crunch!!!
Old May 30, 2009 | 11:53 PM
  #37
what is the problem
Old May 31, 2009 | 12:10 PM
  #38
Old May 31, 2009 | 01:16 PM
  #39
Justinlhc's Avatar
Ummm.....wow. I'm in love. I want a SA standard cab pickup so bad. That looks amazing. How does she wheel in 2wd?
Old May 31, 2009 | 01:28 PM
  #40
not so good, i ordered the driveshaft kit from trail gear. they are starting to piss me off though they keep shorting me parts. they didnt send the rear u bolt brackets, so i had to make my own. everything is on back order with them
