Final SAS BSin
Old Aug 12, 2008 | 07:33 PM
TomkiRider's Avatar
wtf how do u know my name?
Old Aug 12, 2008 | 08:16 PM
TomkiRider's Avatar
scratch that. an i run 35x14.50s with 4.88s? i know it says 35 and up 5.29s but whats the disadvantage, speed? mileage?
Old Aug 12, 2008 | 08:22 PM
TOYOTA 1's Avatar
Originally Posted by waskillywabbit
A mechanic is not a fabricator. A welder is not a fabricator. You need a competent fabricator to install a SAS properly who has not only mechanical skills but welding skills, but moreover, working knowledge of a SAS.
I wish you luck with your SAS, but I think you are getting in way over your head just because of the questions you continue to ask.
Good luck.
those kits are not that hard to install correctly. you guys make it sound scary.
Old Aug 12, 2008 | 08:25 PM
TomkiRider's Avatar
thanks. about the gears....
Old Aug 12, 2008 | 11:54 PM
  #25
just a 22re's Avatar
woooooo i ment abe on yotatech he has a white runner lol i had no idea your name was abe, abe lol
Old Aug 13, 2008 | 08:28 AM
  #26
dirtoyboy's Avatar
Don't underestimate how stupid people can be! It's not hard but if you dont do your research or have poor welding skills it IS scary....
Tomki...Yes 33's would look funny on the 4inch lift...I would go at least 35s to make it worth your while.... For 35+ tires I would run 529s no question. 488s are better suited to 31-34 inch tires. Yes your power will be hurting as well as gas mileage and clutch
Old Aug 13, 2008 | 08:36 AM
  #27
Mic09dcsm's Avatar
I have stock gears and I run 35's nicely. And 14.50's would be WAY too wide in comparison to the height of the tire.
Old Aug 13, 2008 | 09:04 AM
  #28
run4her's Avatar
I have 529's with 38.5/15.59's i wish there was a stronger lower gear.
  #29
dirtoyboy's Avatar
I can't even imagine what that must be like! sorry.....
what is your MPG like?
Can you hold gears on the highway? How much does it dog out from a complete stop? Do you crawl? I would imagine your clutch must hate you
Old Aug 13, 2008 | 09:41 AM
  #30
waskillywabbit's Avatar
X2.
I ran 37 MTR/s with 4.88s and a freshly rebuilt 22RE 5spd as a dd for 18 months and it would take off and hold highway speeds just fine.
Old Aug 13, 2008 | 09:50 AM
  #31
Mic09dcsm's Avatar
I get about 14 MPG and can easily cruise at 70mph, inclines above 5 degrees sometimes require a downshift.
Old Aug 13, 2008 | 10:30 AM
  #32
TomkiRider's Avatar
thats weird theres another abe here. well the 4in sprigs is actually 5 in of lift. how difference in mileage and power between 35s/4.88s and 35s/5.29s?
  #33
TomkiRider's Avatar
could i cruise at say 70 on freeway?
Old Aug 13, 2008 | 10:36 AM
  #34
dirtoyboy's Avatar
http://www.4lo.com/
Old Aug 13, 2008 | 10:53 AM
  #35
TomkiRider's Avatar
thanks that a pretty cool site
Old Aug 13, 2008 | 10:57 AM
  #36
TomkiRider's Avatar
well on there it seems like 4.88s and 35s wouldnt be to bad, 2800rpm/70mph...but i would trust experienced PEOPLE over a computer any day
Old Aug 14, 2008 | 06:21 AM
  #37
SteveMcQ's Avatar
I run 35"(balanced) MTZ's with 5.29 gears. I would not go to a 4.88 ratio if you plan on running on the freeway. My truck seems to hold speed fine once I get over 70mph in 5th gear. If I fall below 70mph, and need to climb a grade or pass, I have to downshift. My truck is low mileage (1987, 94K) and has a header with a 2.25" mandrel bent exhaust and flowmaster muffler. I run a stock carb w/ a knn filter. For a 22r, it runs suprisingly good, but I use all 100 hp to keep it going down the freeway. 4.88's would suck in my opinion.
Also consider that when a truck is lifted (mine-4" t.g. springs in the front, chevies in the rear) they don't slip through the wind like other cars or non-lifted trucks do.
Nobody wants to here that there not geared right, but let me tell you from experience, 4.88's and 35's would be pushing the limits of the mighty 22R.
Hope this helps.
Edit: I posted pretty early this morning and didn't realize you have the 3.0. I still think 4.88's would be pushing it, but that extra torque from the 3.0 would do a better job than the 22R.
Old Aug 14, 2008 | 07:49 AM
  #38
TomkiRider's Avatar
k thanks a lot guys
Old Aug 14, 2008 | 09:46 AM
  #39
Mic09dcsm's Avatar
Hope this helps.
I'm running balanced 35's MTZ's too but mine has a V6 and came stock with 31's so according to this site I have 4.56 gears, it can cruise nicely now, before with 31's it always felt like the gear ratio was too low, now it could be a little higher.
Old Aug 14, 2008 | 12:11 PM
  #40
KODE's Avatar
definately go with the 5.29's if youre gonna run 35's. it makes a big difference in power and mpg....
