Exhaust manifold removal/installation tips
Old Apr 10, 2009 | 02:19 PM
OutlawMike's Avatar
Not an idiot, just a simple mistake. Now you know, and can pass it on to someone else. That's what the forum is all about, sharing knowledge.
Mike
Old Apr 11, 2009 | 04:09 PM
coregrind's Avatar
On the drive home the other day my check engine light comes on with code 71 - EGR. I know the valve is good and the vacuum hoses have been replaced. So it's either the modulator or the vacuum line routing right? I'm not sure if the vacuum lines for everything related to EGR are correct. Is there anybody who can provide a picture of their 3.0 that can confirm the proper routing? Any help is appreciated.
Old Apr 12, 2009 | 08:49 AM
scope103's Avatar
Originally Posted by 24Runna
OutlawMike is correct. There is a measuring device to calculate the amount of air coming into the engine. When you crank the engine it is taking in air, the flap will move slightly ...
That flap also switches power to the fuel pump, to keep the pump running after you release the key from the start position. So if the intake pipe is off, the fuel pump won't run either.
Jayboy74
10
Dec 21, 2021 08:27 AM
Marsheen
Feb 17, 2016 12:29 PM
Corvoid
Sep 4, 2015 11:55 AM
shrek99352
Aug 31, 2015 04:16 AM
