exhaust leak near engine?
Old Dec 23, 2010 | 04:55 PM
benchernif's Avatar
I swear my engine sounds louder - like a puttering exhaust hole - near the driver' side of the engine.
I just serviced the heads and didn't see any holes in the muffler manifolds on each side.
Does anyone know an easy way to find a leak, since this engine is so tight?
I think it's the crossover or the pipe that leads to the rear of the truck, but near the beginning at the front of the engine.
Also - will I encounter a power loss with a hole near the engine side?
Best...
Ben
Old Dec 24, 2010 | 11:36 AM
scope103's Avatar
I'm sure you've gone over this, but remember to visually check that you have all the nuts on the connections. Those nuts probably shouldn't be re-used, and I had one wiggle off after about 200 miles. Produced the sound you describe, and went away with the a new nut.
Old Dec 24, 2010 | 11:37 AM
benchernif's Avatar
Huh...so it could just be a bad nut? I'll look into it. I wouldn't be surprised if I forgot to throw one on when I put the exhaust back together.
I'll give it a look!
Ben
Old Dec 24, 2010 | 01:44 PM
RWGoad's Avatar
Yep, the exact same thing happened to my 92 3.0 4runner this week. It's been getting louder for several months and I delayed the repair due to the fact that I expected the problem to be blown gasket at the head to ex. manifold. How happy was I when I saw that the left down-pipe only had one nut remaining and it was half-way off. As scope103 said it look before you leap, check those bolts. Thankfully they are easy to get to and I even had several in the bolt bin from some earlier engine swaps, etc. Good Luck !
Old Dec 24, 2010 | 02:33 PM
Cfuchs092's Avatar
The same thing happened to my 92 22re pick up not to long ago. i was on my way to work and all of a sudden it sounded as if my truck had a massive hole in the header. I got to work and let it cool off and removed the heat shield over the header and my co worker was watching as i started it up and revved the engine. Turns out i lost a whole nut and stud in the header causing the noise. Check that for sure guarantee thats your problem. Its a cheap fix as well.
Old Dec 24, 2010 | 04:10 PM
rattlewagon's Avatar
Do the seafoam treatment. If there is a hole, youll find it. Seafoam smokes like a mother.
Old Dec 27, 2010 | 04:38 PM
benchernif's Avatar
Fixed!
Everybody talks about Seafoam - can someone enlighten me on what/how to use the the stuff with my 3VZE?
FIXED:
Yup, you guys were correct - one missing bolt and one loose bolt on the part that connects the driver's side manifold to the long-pipe to the rear. Sounds much better now!
Thanks ya'll!
Ben
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
Avenged
Jul 9, 2015 07:55 AM
