Exaust help
Exaust help
Hey, I have a 94 pickup 22re. and im looking for a new exaust set up. Im wondering if its ok to put a Flowmaster 40 series muffler 2.25 and a high flow cat on a stock exaust manifold. and if the high flow cat is a necessity.
You have a stock header? Neato, must have been a dealer option
And a 94 Taco eh? Thought Taco's started in 95.5.
Stock exhaust manifold you mean?
But to answer your question, yes, that's what I'm running on my 22RE now (minus the hi-flow cat).
Depending on the 'source' of the information, Tacoma's were introduced in late 94 as a 95, in parallel with the 'normal' pickups. The Tacoma's have little in common with the regular Toyota pickups though....
.... what engine is in the 94, nick94toyota? Not exactly a show-stopper question but it may make a difference. I wouldn't want too small of a muffler behind a 22re or 2rz, and maybe there's some common ground between a 3vze and 3rz... and 5vze is another topic all together.
Best sounding muffler I've found for a 22RE. I've run cheapo "turbo" mufflers, cherry bomb turbos, glasspacks, etc. Pretty deep, throaty sound for a 4cyl. Most def. needs a tailpipe, don't dump it. No tail pipe makes it sound like an old wet fart that doesn't end.
k thanks. im a youngin. i got my pickup for my 16th bday. Im 18 now and really wanting to get into modin up my truck. But i have to start somewhat slow with the cost aspect. So forgive me for my newbie questions.
Nothing wrong with being young
Im only 19 myself. Everyone has to start somewhere
Thanks, and im sure i can pick those up at a local shucks or auto zone. thanks for all the replies. Its helped a lot.
one last question, will it make a large difference if i were to put a new high flow cat in along with the flowmaster 40? cuz i dont c it as being that important.
I dont have any experience with a hi-flow cat (except when I was 16 and punched one out on my old 90 4Runner....bad idea, but sounded awesome and shot flames at 5500 RPM
To keep the cost down, if your stock cat is good, keep it.
)To keep the cost down, if your stock cat is good, keep it.
To keep the cost down, if your stock cat is good, keep it.[/quote]
thats tight. so it wont be a chinsy set up if i just use adapters and clamps? and do i just wana get a 2.25 tailpipe to stick on there and thats it? seems too easy.
