Engine swap
Old Jun 9, 2021 | 02:42 PM
butt_lemon's Avatar
Engine swap
My 3vze blew in my 89 pickup so I bought a cheap 3vze from a 93 4runner. Before I start rebuilding this motor, am I going to run into issues when I go to start it up? I have both wiring harnesses so I can use either one.
Old Jun 10, 2021 | 05:19 AM
maxvp01's Avatar
You may need to use a different computer for it. I think the pin outs are a little different from that year gap.
Or just use the sensors from your old motor and swap them over to the new one. then the old wiring harness will plug right up to it, and that saves you a few hours of work by not having to change out the harness and computer
Old Jun 10, 2021 | 07:27 AM
butt_lemon's Avatar
Well that isn't as bad as I was thinking. Thanks!
Old Jun 10, 2021 | 08:21 AM
maxvp01's Avatar
no problem! also the throttle bodies might be different, depending on if one motor had cruise control or what not. but i would just swap the whole throttle body over anyways so you don’t need to calibrate the TPS.
RobertS316
Apr 8, 2018 10:26 AM
Jgloade
Aug 28, 2015 03:12 AM
SR5
Jan 16, 2010 05:33 PM
mp_4x4
All Other Toyota Swaps
Apr 24, 2009 07:36 PM
Jollyradar
Aug 30, 2006 09:40 PM
