Engine studders under acceleration
ok i have a 94 4runner sr5 v6 5sp and when i accelerate or go up a hill the rig slightly studders almost like when you shift gears when the rpm's are too low but more subtle. so i am wondering if there was air in the clutch fluid would that cause the problem or maybe the oil leaking from my rear main seal may be causing slippage or if it is an ignition problem. also it looses speed when i go up a hill, even if it is a low grade. please help
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
88runnergomas
Jul 9, 2015 01:12 PM
