Engine removal
Old Dec 3, 2013 | 06:21 AM
Gevo's Avatar
Originally Posted by seabee 86
I do have AC but I have the 4 cylinder not the v6. I'll have to check that out, thanks.
let us know if you find the solution.
Old Dec 22, 2013 | 10:42 AM
seabee 86's Avatar
Does anyone know what this bracket is for? I've installed the whole engine, can't find where the hell it went. *facepalm*
Old Dec 22, 2013 | 11:12 AM
chrisgreene243's Avatar
That bracket is a reinforcing brace for the alternator or p/s pump.
Old Dec 22, 2013 | 11:35 AM
Correction definitely for the p/s pump.
Old Dec 27, 2013 | 06:57 AM
  #25
seabee 86's Avatar
Okay here's another question. When installing the timing chain cover is it recommended to use any type of sealant? I saw no mention of this in the shop manual so when I installed it I only used the paper gasket that came with the timing chain cover. However my timing chain cover is leaking coolant. How do I remedy this?
Old Dec 27, 2013 | 06:58 AM
  #26
seabee 86's Avatar
Chris Greene thanks for the response
Old Dec 27, 2013 | 08:48 AM
  #27
Never hurts to throw some ultragray on that cover. And wheres it leaking from exactly? Pics?
Old Dec 27, 2013 | 09:39 AM
  #28
seabee 86's Avatar
Click image for larger version
It's not a horrible fix, I gotta pull them off, goop it up, and put them back on. It's the working in 20* and 30* weather that's demotivating me.
Old Dec 27, 2013 | 01:51 PM
  #29
Yea, doesn't look too bad. And yes when its that cold ambition is expensive.
kazuya2416
Apr 5, 2024 02:17 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
crashburnoveride
Jul 10, 2015 06:39 AM
ItsJustD
Jul 7, 2015 07:49 AM
