Engine Oil Leak: Anyone Know How To Stop It?
Old Aug 21, 2011 | 08:51 AM
andlours's Avatar
It appears to me that I've got some oil leaking from my engine block on the top. It's not a ton, but it's just a hassle. Is there any simple way that I could fix this? I'm new to all this, so pardon me if I'm completely wrong/asking a stupid question. Thanks.
Attached Thumbnails Engine Oil Leak: Anyone Know How To Stop It?-imag0080.jpg   Engine Oil Leak: Anyone Know How To Stop It?-imag0081.jpg
Old Aug 21, 2011 | 09:05 AM
mightymouse's Avatar
It seems as though there are a couple potential spots that are leaking on your valve cover. One is the line that is a thicker line to the throttle body. To fix this replace the line, add small clamps to said line. The other spot could be your pvc valve. If it's leaking there ( the other similar sized line towards the rear of the valve cover) Check and replace the line along with the pvc valve with the grommet as well. Basically "see where there's oil coming out? replace the faulty part"
Old Aug 21, 2011 | 09:07 AM
92 TOY's Avatar
looks like you are leaking from the PCV valve grommet. costs a few pennies at the store....get a new PCV valve while you are at it....about $6. those grommets get brittle and hard.....PCV gets clogged. good cheap insurance.....good easy job to do too
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Jul 11, 2015 07:21 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
wilbertd
Jul 6, 2015 07:39 AM
