Elusive engine tick. Winner gets a cookie
Old Dec 15, 2013 | 05:24 AM
SLAYfriknBODIES's Avatar
So the new front-running theory is that I have an exhaust leak that remains sealed during lower exhaust pressure at idle, however once the truck gets moving and the engine is pushing exhaust out harder, its leaking through the bad gasket or flange in the exhaust pipe/header allowing me to hear that rougher "chattery inside of the engine noise"
Old Dec 15, 2013 | 05:52 AM
bone collector's Avatar
got a short video of the sound?? I mean after all, we are battling for a cookie here. serious stuff...
Old Dec 15, 2013 | 12:24 PM
The next time I get it over 30, ill lean out of the window and try to get my cell phone up under the driver side wheel well for you guys.
Ill see what I can do about producing the noise in neutral with the hood popped.
One last attempt at a description: It sounds like a cross between when you stick a playing card into bicycle spokes to make that little kid "motorcycle" effect mixed with a light metallic ticking. Its almost like a crappy echo of the engine noise magnified.
Old Dec 15, 2013 | 01:57 PM
combatcarl's Avatar
That first sentence there is gonna be a quote at some point.
Sent from my NSA screened iPhone
Old Dec 23, 2013 | 04:31 PM
  #25
cman1's Avatar
any updates?
Old Dec 23, 2013 | 08:25 PM
  #26
RylerTust's Avatar
Mine ticks at idle pretty audibly like most 22re engines do, I narrowed it down to my fuel injectors, and upon overtaking when I give it more gas while in low rpm under load it gets louder with the amount I push the pedal down. Yours may be injectors, too.
Old Dec 24, 2013 | 04:40 AM
  #27
I don't know guys, it has been over a week. The cookie that once sounded fantastic, now sounds crusty stale and moldy. And for that reason, Im out..... lol
Old Dec 24, 2013 | 06:38 AM
  #28
cman1's Avatar
yeah,i agree,no milk is gonna fix this cookie,i too,am out.
Old Dec 24, 2013 | 01:20 PM
  #29
TNRabbit's Avatar
Originally Posted by sebastianholmes
my exhaust was super leaky and sounded a lot like this. Tighten all the bolts on your header and look for holes or something loose around the cat or muffler.
Originally Posted by combatcarl
Check the break between exhaust manifold and down pipe. There's two metal/paper donuts that fail and leak. Make sure you have three nuts on the studs that hold it together. I was down to one, made a bad sound, was a little gutless.
Originally Posted by Bigblock
Exhaust leak. Give me a Miller Lite.
I agree sounds just like an exhaust leak.
Old Dec 24, 2013 | 02:30 PM
  #30
Bigblock's Avatar
Your exhaust manifold is inboard of that driver side fender well.LOL
Old Dec 24, 2013 | 04:19 PM
  #31
lobukbuild's Avatar
agreeing on the spark knock. check your distributor timing and make sure it is advancing properly under acceleration , even with higher octane itll still detonate under load if its not advancing or timed correctly. it will still start n run but will sharply tick under load. weak spark will do the same. if you find that your coil is weak i recommend a higher voltage aftermarket one like a blaster or super coil. oreo please
Old Dec 24, 2013 | 09:20 PM
  #32
ksti's Avatar
I don't know, could be a nut loose behind the wheel.
Old Dec 26, 2013 | 02:19 PM
  #33
lobukbuild's Avatar
or the blinker fluid
Old Dec 26, 2013 | 03:37 PM
  #34
combatcarl's Avatar
I've had elusive ticks on a dog, too.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
sojourner567
Jul 16, 2015 08:52 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
