EFI to carb swap
Old Oct 27, 2008 | 05:31 PM
slayyerr's Avatar
Originally Posted by desert-rat660
sounds like u need a friend thats good with electrical to help u out
yes i do mate and too bad all my friends are not auto electricians.
i have been looking at the wiring diagrams in the haynes book but i can not figure out what the 3 lines on the bottom mean nor the 5 lines on top mean.
im thinking the 3 lines on the bottom of the page mean it is ground since the w-b wire goes to it, but the 5 on top are puzzling me to no end and there is no legend in the haynes book.
Old Oct 27, 2008 | 05:33 PM
abecedarian's Avatar
the 5 at the top and 3 at the bottom are the common hot (at the top) and ground (at the bottom) wires.
so it sounds like you've got it half figured out.
what might help you figure it out is to photocopy the multiple pages and lay the copies out side by side.
Old Oct 27, 2008 | 05:50 PM
slayyerr's Avatar
well basically all i need is on the one page for the fuel pump, fuel injectors, and the air flow meter. BTW is there any way i can remove the air flow box and just have a normal air filter box?
Old Oct 27, 2008 | 05:55 PM
no. the ecu requires the signal from the air flow meter to determine fuel mixture, and the afm also operates the fuel pump when the engine is running.
okay, maybe I half lied- if you search real hard and have the money, there is at least one afm to maf conversion product for the 22re's. street legal? no. doable? maybe.
Old Oct 28, 2008 | 05:12 AM
  #25
gte718p's Avatar
Tree huggers are your friend. I'm currently living in South East Asia and have been to Vietnam and China recently. Not being able to breath sucks!!!! A large part of their problem is completely unregulated vehicle emissions.
If you get to the point where you think you have wiring problems it might be better to scrap the ECU and wiring and start over with an aftermarket system. My personal favorite is megasquirt.
Old Oct 28, 2008 | 07:26 AM
  #26
1styota4X4's Avatar
I would def. keep the EFI but if not I am looking to swap over to EFI. I have a offie intake(brand New) a weber carb(maybe 400 miles on it) all you need is a fuel pump...You can use a holley blue or black pump for under 100 bucks I may even have one. PM me if interested...If not just start at one end of the truck and start repacing the wireing or at leats fixing the cripmed ends so its done right. Dont go to a aftermarket system it will be more of a headach for you with all the rewireing you will have to do. Then you got to tune it...
Old Oct 28, 2008 | 09:52 AM
  #27
slayyerr's Avatar
thanks mate but im thinking of staying with the original EFI since most say to do so, and i kind of like the EFI.
Old Oct 28, 2008 | 05:01 PM
  #28
slayyerr's Avatar
update on my problem....i found a guy here that actually got my runner running today. it was a major mixup in the wiring and it needs to be rewired. he is going to charge me about 400 dollars to do it.
tomczaksdiesel
Jul 26, 2015 10:35 PM
keithporter83
Jul 24, 2015 07:37 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
