E-brake solution to rear disk swap??
Old Nov 26, 2014 | 02:53 PM
muddpigg's Avatar
I really like the full floater.
But if your using a line lock then it's really not an e-brake just a parking brake. I ripped a brake line out on a trail and was thankful for the e-brake through it doesn't brake very good. Line locks won't work without brake fluid and brake depressed to set.
There are two types of line locks mechanical and electrical. Mechanical ones shouldn't drain battery but gotta run lines to mount it into the cab.
Old Dec 1, 2014 | 08:38 AM
RBX's Avatar
RBX
FJ Cruiser rear disc/drum conversion
Crossreference for rear disc/drum components.(According to Rock Auto)
You will probably need to use IFS hubs, but I cannot confirm this yet.
It appears that all
found on these models:
(note: hub hole for rotors may not fit older 108mm hubs)
LEXUS GX470 (2003 - 2009)
TOYOTA 4RUNNER (2003 - 2009)
TOYOTA FJ CRUISER (2007 - 2009)
TOYOTA SEQUOIA (2001 - 2007)
Rotors with Hub hole @ 108mm as found on older Models with SFA and IFS
LEXUS GX460 (2010 - 2014)
TOYOTA 4RUNNER (2010 - 2014)
TOYOTA FJ CRUISER (2010 - 2014)
Calipers:
LEXUS GX460 (2010 - 2013)
LEXUS LX450 (1996 - 1997)
TOYOTA LANDCRUISER (1993 - 1997)
Old Dec 1, 2014 | 07:53 PM
nothingbetter's Avatar
good point on it being a parking brake and not an -e brake. You mentioned you had a chain drive case, what's stopping you from using a t-case mounted brake? Do they not make one?
Old Dec 2, 2014 | 01:53 AM
muddpigg's Avatar
No, chain drive, gear driven t-cases.
I'll compare cost when a disc conversion that uses stock parking brake comes out.
I had gotten a conversion kit hadn't installed before being stationed in Germany. So truck went to storage at father in laws. Parts went in storage through a storage company but several things came up missing after: disc conversion kit, FSM, 3/4 inch socket set......
Just weighing options, again.
Old Dec 2, 2014 | 02:27 AM
  #25
BigBluePile's Avatar
I like my disc brake conversion. I also like my tcase ebrake. However, I sure would like to have a rear disc ebrake though because of the possiblities of one tire slipping and causing the truck to move......
Old Dec 5, 2014 | 06:15 AM
  #26
RBX's Avatar
RBX
It appears that all
Calipers:
I just quoted myself, next I will refer to my self in the third person...haha.
Just updating some part info.
Old Dec 5, 2014 | 06:46 AM
  #27
muddpigg's Avatar
Nice.
Awesome reference list!!
I need to do some research regarding rim size to clear such a conversion. I don't think 15" rims were a factory option for any of vehicles listed.
Old Dec 5, 2014 | 09:22 AM
  #28
RBX's Avatar
RBX
Hardest part is going to be finding backing plates. New they are around 300$.
I may try to make my opwn backing plates if they aren't too complicated.
Old Dec 5, 2014 | 09:47 AM
  #29
muddpigg's Avatar
Not sure what you mean about backing plates, think I would need to see it.
Old Dec 5, 2014 | 09:51 AM
  #30
RBX's Avatar
RBX
I'm trying to find one with the drum shoes mounted.
Backing plate is essential for a drum brake to function, unlike a disc/caliper set-up
Old Dec 5, 2014 | 11:32 AM
  #31
clok's Avatar
Originally Posted by muddpigg
Nice. Awesome reference list!! I need to do some research regarding rim size to clear such a conversion. I don't think 15" rims were a factory option for any of vehicles listed.
exactly what I was thinking might have to upgrade to 16" rims.
Old May 5, 2015 | 07:11 AM
  #32
stanz's Avatar
Curious if anyone has tried late 80s/early 90s RX7 rear calipers for their swap? The are side pull cable by design.
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 9, 2015 02:12 PM
toyoda8488
Jul 5, 2015 10:18 PM
