Drum roll please!!! new addition to my toyota family
Old Sep 30, 2009 | 06:55 PM
camo31_10.50's Avatar
ok guys..its a done deal i just got back from Alma, AR pickin up the new addition to my toyota family i got goin on ('80, '86, now '92)
went real smooth..turns out i have to buy an oil pan, oil pan bolts, tie rod nut that holds the tie rod onto the pitman arm, and a couple of cotter pins..just to start
the body ground coming off of the battery is burnt in half for some reason..im thinkin something's messed up somewhere unfortunately..wires dont just burn up..(although its not very big gauge wise??)
so..i know everybody is gonna say WHERES THE DANG'D OLE PICS!!!!!!!!
but they will have to wait until tomorrow as it is way to dark outside now HAHAHA
it has a Toyotaoffroad.com windshield banner on it so i'm gonna see if i can find the previous owner on that website!!!
PICS TO COME I PROMISE!!!!!!!
Old Sep 30, 2009 | 07:03 PM
toyota4x4907's Avatar
'Tis a 4runnuh?
Old Sep 30, 2009 | 07:10 PM
CHYA!!!! tis a forunna!!!!!!!!!!!!!!!!
omfg i am in loovvee with this thing..
but idfk how to open the rear hatch!!?!?!?!?!?...
it has a key hole on the outside..that does nothing..
and it has no handle on the outside??
it has a handle on the inside..that doesnt work too!?!?
im gonna throw a good battery in it..replace the battery cables..and see if i can get some electricals (after i check all the fuses of course)
Old Sep 30, 2009 | 07:14 PM
CO 4runner's Avatar
hahaha well whats supposed to happen is when you turn the key in the tailgate, the window rolls down. Then you can use the inside handle to drop the tailgate. If both are broken though, that would make things difficult.
Congrats on the new toyota, and welcome to the 2nd Gen 4runner Family!
Old Sep 30, 2009 | 07:16 PM
the key is for the window?!?!? really or are you just pullin my log chain!?!? lmao
i'm gonna feel like a complete idot either way HAHAHAHA
Old Sep 30, 2009 | 07:18 PM
i get why you have to roll the window down now...
man i do feel like any idiot...........................
Old Sep 30, 2009 | 07:19 PM
pwd's Avatar
pwd
Yep its for the window, I don't even think I've used mine yet but thats the only way it opens. If you have time you may want to give the window/ tailgate some TLC. Mine works put it seems like it struggles a bit.
Old Sep 30, 2009 | 07:20 PM
pb4ugotobed's Avatar
you'll have to roll the rear window down, then unlock the tailgate to open it. You can do it with either the switch at the center console, or the key cyl in the tailgate itself if stuff is working.
If it won't work, first make sure the rear wiper is in its "home" position. If it isn't, rear window won't work. Make sure the rear window lock switch isn't "locked". This switch basically interrupts the ground wire going to the rear window ECU/Relay board. If this lock switch is bad, then the rear window still won't work. Mine was bad, I just bypassed the window lock switch. If you need me to scan the Toyota EWD for the rear window circuit just let me know and I can email it to you. I keep the EWD in my truck "just in case"
Old Sep 30, 2009 | 07:23 PM
me+wiring basically ANYTHING= big no no..
i"ll have my dad check it out once i get the new battery and cables put in it. im hoping by then i will atleast be able to get some power to everything to see what works and what doesn't!
Old Sep 30, 2009 | 07:39 PM
I could teach an ape to wire a car... if you need any help just let me know.
Old Sep 30, 2009 | 07:41 PM
LMAO will do mister P! (love your name hahahah) thanks for the help!!!!!
Old Sep 30, 2009 | 08:03 PM
Jay351's Avatar
The rear windows are famous for corrosion/rust issues.
Once you get the tailgate open pull the panel off and grease all the tracks. I bet they are dry as a bone!
Then you can check the condition of the motor and so on.
Old Sep 30, 2009 | 08:18 PM
thanks Jay!..i'll be doin alot of little things like that tomorrow!
like putting a couple pieces back on the dash where the PO took out the stereo
getting a nut and 2 cotter pins for the tie rod
and probably checking to see if i have any play in the crankshaft main bearings or rod bearings
the rod bearing that was screwed on my '86 WAS BAD!!!! i could hold the rod end cap (while the rod is still in the motor with just the oil pan off) and i could move it about 1/4 in LOL
if i dont find anything wrong just by doing that..then im going to turn the motor over by hand and keep checking..and find out what the knock is
heck it dont even have any damn oil in it right now!!! the Ahole took the pan off and did something with it..idk what..
Old Sep 30, 2009 | 08:29 PM
Jay351's Avatar
Haha, what the hell?
AZkid's Avatar
hook a battery up to the window and rollit down and remove the cover and pull on the two cables, one on each side, and waa laa, your tailgates open.
Old Sep 30, 2009 | 08:42 PM
Jay351's Avatar
Yeah, I forgot to say that, if you can't get the window down. Just apply direct power to the motor (switch power/ground to change direction of the motor).
If the motor is bad you can replace it with a motor from any door from a pickup or 4runner..
Old Sep 30, 2009 | 08:55 PM
i feel like a newbie all over again LOL
yea i know how to open the tailgate now..lol that will probably be helpful though!
ok..so the plan is tomorrow..nitpick at a few things..take this apart and clean it..clean this..clean that..grease this and that..put some dash panels back on..
and then the real fun will hopefully start this weekend!! im actually excited about getting to work on another vehicle!! hahaha
Old Sep 30, 2009 | 09:06 PM
AZkid's Avatar
if you need a window motor i got a spare ill sell you for cheap.
Old Oct 1, 2009 | 12:15 AM
kiyobrown's Avatar
Too bad you are in OK. There is a yard up here in WA with half a dozen 2nd gens and they just about give parts away. I usually walk away with a load of parts (ebay value over $300) for less then $100. Come to think about it, I should scalp some parts on Fleabay to make some header money!! YESS!!
If there is something you really need and can't find, let me know, next time I go there I will take a look for you.
Lookin forward to the pics.
Jason
Old Oct 1, 2009 | 01:36 PM
welll heree ya go..the fricken dodge was ridin on the bumpstops the whole way home though..killer on my dang back
but shes here..and i found an '88 3.0 thats in GOOD running condition in a rolled 4runner..didnt ask about the mileage but i will later today! heres the pics of it at the house..and random of the runna!!
what is that?!? it looks like a mount..its just on the t-case????
small leak at the pinion seal (i think thats what it's called??)
2 of the BFG's have this much tread
the other 2 have this much
ewww..thats rusty lookin...
yep its rusty i believe i want a coolant system flush and a new radiator!
the interior is AMAZING!!!!!!!!!
K&N DUDE!!!!!
3.slloooowwww
what connects here??? (the hose in the middle..lol)
