Drive Shaft Issues
Old May 1, 2007 | 10:16 PM
EFB16ACRX's Avatar
Originally Posted by MudHippy
Yeah, it will simulate a bad u-joint there at that flange by lettings things wobble around, vibration city. Either the flange nut being loose or the worn bearing. I've experienced all three on my truck, felt basically the same when driving. Rear driveshafts are my nemesis. Replacing the seal is a piece of cake(shouldn't take more than 45 min tops), the bearing on the other hand, is QUITE a chore. Somebody has a write-up for doing the transfer case rear output shaft seal, rock-auto or napaonline has the seal cheap. I could tell you what's involved with the bearing, if your curious.
does the case have to come out for the bearing? driving 300 miles on a bent driveshaft fubared mine.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
andrewtexas123
Jul 14, 2015 04:29 AM
nick b
Jul 11, 2015 04:38 AM
