Does Cold Air Intake Give Better Milege
Old Jun 1, 2008 | 07:17 PM
  #41
TomkiRider's Avatar
in milage? how much?
Old Jun 1, 2008 | 10:50 PM
  #42
machine23's Avatar
on my 94 3.slow i pulled out all of the restrictive plates in front of the air box, bought a 3"flexible plastic air ducting hose made by spectre, stuck that into the hole on the air cleaner box, dropped a k&n stock replacement filter, and now im getting 24mpg. when its sunny and rain-free i extend the ducting hose up to where the hood comes down and it has a cold air feed right there. if it starts to rain i just push the hose back down so it wont catch any water. thats basically a cheap mod that you can consider a cold air intake without the restriction. and its really no hassle at all to just adjust it when needed. the person who owned it before me said she could get 18mpg. thats with all the plates in front of the box. and just a fram filter
Old Jun 2, 2008 | 10:00 AM
  #43
4Run_95's Avatar
I have heard that cold air intake decrease milage since cold air has higher density= more air in cylinder= more fuel needed. A little bit like a turbo, but much much weaker effect. Im thinking, if you do something similary on a carb. you would have to get a bigger jet= more fuel ...
But, perhaps this is not correct...
Old Jun 2, 2008 | 10:18 AM
  #44
Red_Chili's Avatar
It isn't. More air density = more cylinder filling... some additional fuel is needed to balance, given the throttle is not moved for the comparison. However, if more power is made, less throttle is needed than before, resulting in marginal economy improvements.
Inflating your tires to a higher psi would probably net as much.
Old Jun 2, 2008 | 05:44 PM
  #45
FredTJ's Avatar
And YOUR mileage before this mod was ?????
Fred
Old Jun 2, 2008 | 05:53 PM
  #46
tc's Avatar
tc
"Does cold air intake give better mileage?"
SURE! If you pick your tanks right, it can be huge!
Puhleeze people - there is so much variability in the tank-to-tank gas mileage that unless you do a significant sampling (like 10 tanks before and 10 after) it's not really a valid comparison.
How many of the people above are comparing one tank before to one after? Or better yet, their recollection of what they got before to one accurately counted tank after?
Old Jun 2, 2008 | 06:02 PM
  #47
HAVOC's Avatar
I would say no. Cold air intakes are installed for performance. If your looking for more MPG look someplace else. Why? Cold air is more dense (takes up less space than hot air), the more air you stuff into an engine the more fuel you will use.
Old Jun 2, 2008 | 07:01 PM
  #48
FredTJ's Avatar
Yup, you won't see any increase, especially on these vehicles that pass less gas than a gnat fart.
Heated air will help, as will heating the gas some before delivery.
Look at what some of the newer vehicles are doing in that department.
The newer Mustangs, for instance, have an air heater in the intake.
Hotter air and/or hotter gasoline makes for much better gas atomization which means easier ignition, better burning characteristics, better mileage and more power.
Fred
Old Jun 2, 2008 | 08:11 PM
  #49
4x4YOTA's Avatar
I gained about 1-2 mpg but I drive with a light foot (economical) unless Im showing off
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
ty1er
Jul 19, 2015 06:42 PM
