does anyone actually wheel their truck with 33x12.5 and ome coils?
Old Jun 9, 2009 | 08:02 AM
94Runner4x4's Avatar
Originally Posted by Lumpy
I was never really fond of the body lift, what I do like on the Runners is that the gas tank is raised...I really do no like how low mine sits...
The other side is where you will see the gas tank.
Old Jun 9, 2009 | 08:08 AM
Lumpy's Avatar
Yes, thank you...does the tank not rise with the body though? I thought it was mounted to the body not the frame? I maybe mistaken... It may have been a mod that I had seen, raised take after body lift????
Old Jun 9, 2009 | 08:16 AM
No the tank stays with the frame. But I do think there is a mod to move the tank up, like you said.
Old Jun 9, 2009 | 08:25 AM
Lumpy's Avatar
Ok Cool, I thought it moved with the body, it was the only reason I was considering a BL...I don't like how low the tank sits...seems like it would be easy to bangup.
Back to the original thread...Turbo may be right here, backspacing...I want to see how bad mine will rub, I'll get it out in the yard tonight. I have a few stumps i can get the wheels on to flex (IFS ) out.
Old Jun 9, 2009 | 08:12 PM
  #25
FetusGoulash's Avatar
Originally Posted by Hophead
Just throwin this out there...
Looking at your set up Inoticed you did not mention any sort of panhard drop bracket. When you lift your truck withoutnadjusting the pivot point/or length of the panhard bar your axle is offset to the passenger side. I noticed in your vid its the passenger side thats rubbing. Have look to see how off-center your axle is.
The axle is centered fine. the drivers side tire stuffs up in there just the same. I also forgot to mention that i removed the rear swaybar, but that wont make any difference.
I suppose it is the offset of the wheels and the width of the tires causing the issues. Last time i listen to the masses on a forum
and i do not plan to do a body lift or buy smaller tires. the truck does not need more money put into it to solve this issue. i will cut metal to fix this
Old Jun 9, 2009 | 09:20 PM
  #26
Alex 400's Avatar
The last thing you need to do is make our trucks more top heavy! lift with tires, not suspension. the key to a really solid trail truck (IMO) is ground clearance, not overall height. some good cutting should take care of your problems.
Good luck
Alex
Old Jun 9, 2009 | 09:42 PM
  #27
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Yes, a 1" bodylift will raise your center of gravity, 'bout .5%. But since your not going that route, and doing the saws-all thing, you don't to need worry anything 'bout that.
Old Jun 9, 2009 | 11:31 PM
  #28
Alex 400's Avatar
i agree! do what he said! get out the saws-all and have at it.
Old Jun 9, 2009 | 11:42 PM
  #29
Alex, did you read the whole thread? Lol. I went the 1" bodylift route. Looks a hellva lot better than cut fenderwells. The OP said he wasn't going to do the bodylift. I agreed that a bodylift does raise the COG, but the 1" lift raise it by only .5%.........lol
Old Jun 10, 2009 | 03:34 AM
  #30
Lumpy's Avatar
Here's a poser from yesterday...
Oops
With the bumper bracket gone, The tires have room to move. I think I'm going to get coils before I wheel her though. Plenty of room in the front, not so much in the back.
Old Jun 10, 2009 | 04:59 AM
  #31
yoder519's Avatar
fetasgoulash do you have 15x10 in wheels or 15x8s? i couldnt find it anywhere in your posts i may have missed it
Old Jun 10, 2009 | 06:52 AM
  #32
15x8 and 3.75" backspacing
Old Jun 10, 2009 | 12:43 PM
  #33
space-junk's Avatar
hey, freak, accroding to 4crawler, a body lift only raises the COG ~75% of what a suspension lift would... thus making it a better option of mild lift over coils and whatnot, and it makes sense... even tho the body gets higher, your big arse chunk of steel frame is stayin down low...
Old Jun 10, 2009 | 12:44 PM
  #34
Lumpy's Avatar
Makes sense, good to know...
Old Jun 10, 2009 | 01:11 PM
  #35
Alex 400's Avatar
yeah i did read it. I guess i think about what i would do. If i cut the fender wells i would put some kind of flare on to cover up the nasty lookin' edge. really my distain of body lifts comes from the 2-4" body lifts that some trucks have. I will probably end doing a 1" body lift to clear a motor swap. an inch is ok. !
Old Jun 10, 2009 | 01:42 PM
  #36
an inch is perfect...but hopefully you don't hear that too often.
Old Jun 10, 2009 | 02:41 PM
  #37
Very true. I think thats the 3" lift. It seems to me I read in another post that TC said that a 1" will only raise your COG 'bout .5%. But don't quote me on it, I'm going from what I remember....I could be wrong on the percentage.
Old Jun 10, 2009 | 02:59 PM
  #38
corax's Avatar
trim the rear bumper back a bit and open up the wheel wells a bit (looks like you'd just be cutting out the rusted bits anyway)
*edit* didn't see this was already mentioned
Old Jun 10, 2009 | 03:33 PM
  #39
space-junk's Avatar
good luck finding a decent looking set of fender flares... to the best of my knowledge, only bushwacker makes flares for our 2nd gen runners and hear tell they are kind of cheesy...
Old Jun 10, 2009 | 09:29 PM
  #40
I am a composite manufacturer by trade so i will make my own set of flairs with very little effort. I will post pics when said flairs are built.
thanks for all the advise people
