Dizzy ?
Old Dec 25, 2012 | 05:46 PM
mugen2008's Avatar
Dizzy ?
95 3vze dizzy v6auto
Tested terminals on dizzy while hot. G1 and g2 test good but the ne terminal shows no signal. Tested them all at ambient temp and they al registered signal. Wanna confirm that all terminals need to register ohms while hot before buying new dizzy. Timing mark jumps all over so can't nail timing. Also have code 52 changed both the knock sensor and pigtail and rewired with shield wire and still have code. Wanna nail timing to eliminate possible timing being off would set the knock sensor
Old Dec 25, 2012 | 05:52 PM
ThatGuy1295's Avatar
dizzy?
Old Dec 25, 2012 | 05:56 PM
Timing is jumping all over becuase you have to jump a couple terminals to time the 3vz. Forgot which ones, think its TE1 and E1 or something pretty easy.
Old Dec 26, 2012 | 12:01 AM
mugen2008's Avatar
Dizzy= distributor. Lol
Yah when I shot timing while cold just to c the timing mark stayed in one spot. When the motor reached temp I shot again and it was jumping. I then proceeded to put car in neutral, jumped the diagnostic terminals and shot again and it still was jumping up and down retard then advance. Tested the distributor and it checks out fine. Only thing I can think is that the brand new aftermarket knock sensor I installed was faulty. I am stomped right now.btw still got the code 52 with changing all the the components out.
mtb_taco
Oct 5, 2015 04:36 PM
bhaithc
Sep 17, 2015 07:53 PM
insadj05
Aug 23, 2015 09:11 PM
KBar
Aug 3, 2015 05:14 PM
88yodabasket
Jul 13, 2015 01:32 PM
