diy dent removal
Old Dec 27, 2015 | 02:27 PM
maroonyota's Avatar
Thumbs up diy dent removal
Best way to remove these dents? Its ok if paint chips or cracks bout to repaint, just seeing what ideas or shortcuts yall have used!Name:  20151227_170713_zpshtnzpdan.jpg
Size:  732.1 KB Name:  20151227_170730_zpsvrywf5nj.jpg
Old Dec 28, 2015 | 07:27 AM
Lons81's Avatar
Buy or rent a stud welder and puller, would probably be the easiest to use
Old Dec 29, 2015 | 12:25 AM
davehaynes1's Avatar
a stud welder would ruin your paint and maybe put little holes in your pannel...... but if you dont care about that and you simply want the dents out and dont want to rent one. a trick we used to use was drill a very small hole, screw some LONG screws in slights, clamp some mole clamps to the end and gently hit it out with a hammer.
not great but works a treat to get the big dents out
Old Dec 29, 2015 | 04:06 AM
Obmi's Avatar
I have (Way in the past) putt a soccer ball between panels and inflated it. But that will depend on the strength of the back panel.
Eugene13
Dec 25, 2015 02:51 PM
Zach_trun
Dec 23, 2015 10:33 PM
Obmi
Nov 27, 2015 03:13 AM
Brandon Dodson
Nov 15, 2015 07:55 PM
mysteryfish
Nov 9, 2015 01:11 PM
