Did I get a bad part? Power Steering Gear Box - Pressure Line Fittings
Old Oct 15, 2019 | 04:31 PM
rayt871's Avatar
1989 Pickup, 3VZE 4WD
Hi guys.
So I'm replacing my power steering gear box- ordered a brand new one and everything looks right, fits correctly, etc, except after I filled it with fluid it leaks through the pressure line-in fitting. Not through the threads, but up through the center of the fitting. Upon closer inspection I quickly realized that the port on the new box does not match the one on my original. My original gear box ports have like a conical brass washer inside the threads, Image 1:
The new one clearly is missing that piece (Image 2), and the threads bottom out before the fitting touches anything, so obviously it leaks.
So my first question is- is that conical piece in there something that has to be installed? And maybe I didn't get those washers with my new part? Or do I maybe have the wrong part entirely and that a different kind of fitting?
Image 3 is the picture from the website where I bought the new box- to me it definitely looks like those washers are supposed to be there.
Any thoughts?
Thanks!
Original part
New part
Original part
New part
Photo from where I bought it
Old Oct 15, 2019 | 05:36 PM
millball's Avatar
You should be able to use a smooth, tapered punch, or similar and remove that cone seat from your old box.
Seat the punch tight into the cone seat and wiggle it sideways a bit, and it should come out.
Old Oct 15, 2019 | 05:44 PM
rayt871's Avatar
A ha! That worked! Thanks man.
Loosened em with the punch and popped em out with needlenose.
I'm like 95% sure those were not in the box when I got the part, but oh well, this should do.
fasternu_674
Oct 9, 2012 07:10 AM
cap85
Apr 7, 2012 12:04 PM
BURR2OF4
Sep 14, 2011 11:39 AM
DoveGray85
Jun 19, 2009 05:13 AM
