A.D.D axle shaft vs. Manual axle shaft
Old Oct 5, 2022 | 02:04 PM
Gevo's Avatar
Hey folks, so I am seeing something on the toyota parts catalog that I am having a hard time believing. According to the catalog the two driver side axles have the same part number for manual and ADD setups. I figured the ADD axle shaft would be shorter since it needs to be connected to the diff through the ADD system instead of go all the way to the differential. According to the two catalog drawings both are part number 4130935010, depicted in the images as 41309F.
With this another question. I can't find anybody who has broken the ADD system before. The CV and passenger side axle stub seem to be the breaking points. I broke my axle stub this weekend, it was a heck of a fun day! So I am thinking to get rid of other weak points in the system. Thoughts are appreciated. Thanks!
Old Oct 5, 2022 | 02:55 PM
MaK92-4RnR's Avatar
86-95 IFS ADD or non-ADD are the same exact differentials other than the obvious. This means the use the same CV joints and/or axles.
Old Oct 7, 2022 | 05:04 AM
rattlewagon's Avatar
Your add pic part number looks edited. They have to be different part numbers... They even look different in the pics
Old Oct 7, 2022 | 09:37 AM
Gevo's Avatar
That is exactly why I am confused. So Ill go to different websites and see if this one has an issue.
Reason why I am looking for the difference is to potentially replace my add system with a non add. I broke the stub shaft on the passenger side doing a series of tough trails. I want to remove other failure points in the system.
Old Oct 7, 2022 | 10:56 AM
Gevo's Avatar
Well, I found this on another site. I guess I should check a third site to confirm. Looks like NON A.D.D does have a slightly different part number.
BMarino
Feb 27, 2019 06:13 PM
A2theK
Aug 26, 2013 10:07 PM
dustins
Oct 31, 2009 09:47 AM
cabbage
Apr 11, 2004 07:39 PM
