a.d.d. to aisin hubs
Old Jan 19, 2007 | 12:26 PM
olharleyman's Avatar
Just wondering if anyone can tell me if there is anything special i will need to do to install aisin hubs on my a.d.d. system or if it just a remove and install process??
Old Jan 19, 2007 | 12:27 PM
da_bigg_wigg's Avatar
remove, install manual hub. it's almost too easy...
Old Jan 19, 2007 | 12:59 PM
Dublin's Avatar
" Search " is your friend
https://www.yotatech.com/forums/f128/aisin-manual-hubs-2nd-gen-4runner-76353/
Old Jan 19, 2007 | 01:12 PM
89macrunner's Avatar
make sure you have add and not auto hubs
if you have auto its still easy bot more work.
Old Jan 19, 2007 | 01:23 PM
BC Rider's Avatar
Yup.
You basically remove a steel splined hub, and replace it with the locking hub.
Be aware that when your new aisan hubs are unlocked, that you loose the syncronization between the ADD and the halfshafts. So DO NOT shift on the fly unless your hubs are locked up.
Old Jan 19, 2007 | 01:51 PM
eric-the-red's Avatar
It's more like swear at and beat on pesky cone washers for an hour or 2, remove, install manual hub, search garage for missing aforementioned cone washers
ladybugRC
458
Aug 21, 2020 10:41 AM
G-off
Dec 29, 2015 12:44 PM
Toys4parts
Sep 26, 2015 01:56 PM
mxdw88
Sep 20, 2015 03:13 AM
