cylinders 5 and 6 are dead
Old Sep 16, 2012 | 06:39 PM
89 3.0 yota's Avatar
i have a 89 3.o v6 and i am having problems getting it to run on all six cylinders. i have 150psi of compression,good spark,and good injector pulse. i swaped 5and 6 injectors with 1 and 2 to see if the problem would follow it did not. when it runs for a bit you can pull the plugs out of 5 and 6 cyl. and they are black with carbon. i am stumped not sure how to get 5 and 6 back firing.
Old Sep 16, 2012 | 06:48 PM
waskillywabbit's Avatar
www.ncttora.com/fsm
:wabbit2:
Old Sep 16, 2012 | 11:36 PM
TNRabbit's Avatar
Check for spark on plugs 5 & 6.
You've ruled out injectors & have good (if low) compression, so it's got to be spark related.
Was compression check with engine warm, all spark plugs out, wide open throttle, & VAFM disconnected per the FSM?
Old Sep 17, 2012 | 04:09 AM
I have good spark at the sparkplugs. I did the compression check with them all out. Also a running compression check. Could it be something in the valve train.
Old Sep 19, 2012 | 09:17 AM
Kingjerd's Avatar
Injectors?
Old Sep 19, 2012 | 01:33 PM
TNRabbit's Avatar
Valve train issues would show up in the compression, so I doubt it.
Originally Posted by Kingjerd
Injectors?
^^This is more likely.
Old Sep 19, 2012 | 02:18 PM
j2the-e's Avatar
How did you check for spark? Did you look at it or did you use something like this?
http://www.sears.com/shc/s/p_10153_12605_SPM6522673507P
4.34runner88
Feb 7, 2016 02:24 AM
TOYOTASC
Sep 10, 2015 05:18 PM
old87yota
Sep 9, 2015 12:39 PM
zz_denis
Sep 6, 2015 03:43 PM
Squigglez
Sep 4, 2015 07:33 AM
