cylinder head oil leak
Old 01-29-2011, 02:57 PM
durst's Avatar
had cracked head on 22r so i bought a new head and gasket kit installed it and now there is oil leakingfrom between the head and the front cover. i noticed that when i had this apart the top of the block and the top of the timing chain cover were not flush. would rtv or some kind of sealent solve this.
Old 01-29-2011, 05:12 PM
fierohink's Avatar
Okay so you have the block, the timing cover bolts to the front of that, and the head bolts on top of both. Is the gap between the T-cover and the block, the T-Cover and the head, or the head and the block?
They should all be flush, so I would think something is awry.
Old 01-29-2011, 05:33 PM
Ezrider_92356's Avatar
you are suppose to put a dab of rtv where the block hg and timing cover all come together when you assemble but they should be flush if your block was decked at some point its possible that could account for a slight difference.
Old 01-29-2011, 06:10 PM
xxxtreme22r's Avatar
timing cover and block should be flush, and rtv is supposed to be used. Even says it in the service manual. I think it also shows a picture too for those who only look at photos in the fsm.
Old 01-29-2011, 06:16 PM
barrel roll's Avatar
Yes, you can use RTV to seal it up. BUT you are going to have to pull the head and clean all the oil out of the contact area.
Use the black stuff, clean the contact areas with rubbing alcohol, break cleaner or electric parts cleaner (all pretty much the same thing), lay a nice thick bead and let get tacky, install and torque head, let cure for 24 hours.
Old 01-30-2011, 07:32 AM
durst's Avatar
the timing cover is slightly lower than the block. its not much but that is where the leak is
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
jakebarrett
07-10-2015 07:15 PM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: cylinder head oil leak
