Old 02-10-2016, 09:29 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
CV, Ball joint, TRE, replacement write up with PICTURES!!
Old 06-09-2012, 02:53 PM
  #61
TURBOrunnerNM's Avatar
Originally Posted by lastname_firstname
I did it last night, you have to unscrew the lower ball joint and pop the knuckle off of it and that gives you enough space to slide it past. I had to pop three of The bolts on the side shaft side of the diff off to get it past them...used a 5 lb sledge and a few good wacks with my 1/5 in. Extensions. Good luck
dude...you're my new SAVIOR. those damn bolts..had to use a regular hammer and a crowbar but got them off! then that darn CV slipped right over the diff lip. i appreciate your reply earlier! i was starting to get a stroke from frustration haha. I assumed those bolts were mated with the flange and I'm sure glad you said you could pop them out. THANKS AGAIN!
Old 06-09-2012, 04:20 PM
  #62
lastname_firstname's Avatar
No worries brotha, glad I could help.
Last night I was starrting to think that my suspention might be bent or something cuz I juust COULD NOT get it out. I got so mad I ended up grinding my old cv in half just to pull it out haha before I drank a beer and started at it again with a clear head. Didn't realize the ball joint needed to be loosened until in was doin install but whatev, I was gonna replace it all anyways, and I work in my garage with VERY limited tools
Old 06-09-2012, 05:33 PM
  #63
haha that's the ONLY way to do it! beer and a minimal tool selection, always gets the job done. besides, we need a CHALLENGE!
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
ItsJustD
07-07-2015 07:49 AM
ptb12
07-05-2015 01:49 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: CV, Ball joint, TRE, replacement write up with PICTURES!!
