CT26 upgrade
Old Sep 21, 2018 | 06:07 AM
87-4runner's Avatar
Old Sep 21, 2018 | 06:08 AM
87-4runner's Avatar
Old Sep 21, 2018 | 07:08 AM
jakey poo's Avatar
Please drive to Oregon and take me for a spin
Old Sep 21, 2018 | 04:08 PM
87-4runner's Avatar
would love to see Oregon... maybe someday...
Old Sep 23, 2018 | 12:49 PM
  #25
87-4runner's Avatar
Old Sep 23, 2018 | 01:58 PM
  #26
Co_94_PU's Avatar
Self regulated boost pressure, wish mine did that. I start feathering the throttle at 8, cause diesel turbo don't care
Did you add a blow-off valve?
Plans for an intercooler?
Old Sep 23, 2018 | 03:56 PM
  #27
87-4runner's Avatar
no intercooler...
no the internal wastegate seems to be doing ok...
i think the turbo header and the additional supra AFM combo with the ct26 are a nice compliment to each other... haven't had to do much of any tuning... fired it up and started driving... it may need some after all the leaks/ bugs/ cracked header already... get fixed... but, in spite of those little gremlins I'm very impressed....
Old Sep 23, 2018 | 05:31 PM
  #28
Co_94_PU's Avatar
A blow-off valve goes between the turbo and the throttle plate, it prolongs the seals in the turbo (prevents surging) by releasing the pressure in the charge tube when the throttle is closed. Not to be confused with an external waste which releases the pressure in the exhaust and regulates boost.
Now I typed all that I forgot exactly what you said, but it's relevant.
Have you managed to hit the "fuel cut off" yet, actually cuts ignition but that's another story? I don't think it's as prevalent on a stick shift, on my automatic it will happen anytime I'm hard on the throttle and it drops out of OD.
Old Sep 24, 2018 | 09:56 AM
  #29
87-4runner's Avatar
no fuel cut... it keeps pulling...
Old Sep 24, 2018 | 09:58 AM
  #30
87-4runner's Avatar
all the way to near 5500rpm
Old Sep 24, 2018 | 10:16 AM
  #31
Co_94_PU's Avatar
Looks like I may have to try that supra AFM swap! I'm still gonna blame my turbo if that doesn't workout.
Old Sep 24, 2018 | 05:18 PM
  #32
87-4runner's Avatar
good luck finding one... i found one in canada... Southside salvage in weyburn sk...
$75 purchase $37 import tax $17 shipping ups
Old Sep 28, 2018 | 05:18 AM
  #33
87-4runner's Avatar
Well things keep going south...
i can't seem to stop leaks... everything is so hard to reach and I've started round 4 with this issue... I'm going to take the whole darn thing out and start from scratch so i can reach the unreachable...
hope to report back all is well....
Old Sep 28, 2018 | 07:31 AM
  #34
jakey poo's Avatar
That's definitely a bummer! Keep at it, you'll get her all sealed up soon enough!
Old Sep 28, 2018 | 07:37 AM
  #35
Co_94_PU's Avatar
I find your lack of details disturbing
had to crank another quarter turn into the oil filter relocation plate when I was under mine last time. That's the easy one, the rest I am probably going to have to suffer with till spring again at which point I'll prefer to be in it instead of under it.
Good luck!
Old Sep 28, 2018 | 08:17 AM
  #36
87-4runner's Avatar
Sorry... first time the header gasket leaked away the bottom... second crack in the header... third the turbo outlet gasket... fourth the wastegate flage gasket... argh... one by one I'm getting then sealed but it's been a pain in the buhooty... some of the notes are almost impossible to reach when it's on the truck soooo I'm going to take it back off and I'll take some pics where the issues have been and what to look for if your doing a turbo upgrade...
Old Sep 28, 2018 | 08:19 AM
  #37
87-4runner's Avatar
Sorry... first time the header gasket leaked at the bottom... second crack in the header... third the turbo outlet gasket... fourth the wastegate flange gasket... argh... one by one I'm getting then sealed but it's been a pain in the buhooty... some of the nuts are almost impossible to reach when it's on the truck soooo I'm going to take it back off and I'll take some pics where the issues have been and what to look for if your doing a turbo upgrade...
pics will help explain the issues
Old Sep 28, 2018 | 09:39 AM
  #38
Co_94_PU's Avatar
I've had to resecure every one of those except the stock exhaust manifold hasn't blowen out the gasket yet, it's been known to try to throw the studs out but it's beefy enough to hold the gasket with "most" of them in place.
My turbo sits much closer to the steering than yours, can't imagine I could get at the inner forward turbo to exhaust nut otherwise.. The rest is lots of cursing, some blood sacrifice, and pretty much a different tool or tool configuration to get at every nut and bolt..
Old Sep 28, 2018 | 05:22 PM
  #39
87-4runner's Avatar
exactly... lol
well i got the leaks stopped this evening... yes some knuckle busting, bruises, and a little cursing...
went back to the oem manifold, lost some performance but that ok for now....
Old Oct 11, 2018 | 06:22 AM
  #40
87-4runner's Avatar
Modified my charge pipe after blowing a silicone coupling before the mod.... now the charge pipe butts up against the turbo outlet, so the hose and clamps just hold it in place...
