Crank shaft pulley loose
Old Feb 21, 2012 | 05:15 PM
Teuf's Avatar
https://www.yotatech.com/forums/f114...81-2wd-126295/
Old Feb 21, 2012 | 05:16 PM
Teuf's Avatar
Ooooops forgot to add text. Take a look at this to stop leaks.https://www.yotatech.com/forums/f114...81-2wd-126295/
Old Feb 23, 2012 | 07:22 AM
linkspast's Avatar
Got her done thanks for all the help...
I made a time lapse. which is here
Harmonic Bliss</p>
Old Feb 23, 2012 | 07:32 AM
farmerj's Avatar
you really should have replaced your front main seal. It was worn flat to the groove in the old balancer. It's a likely weak point and will cause you a leak within the year.
You can do all of this with just removing the fan clutch and the radiator shroud and all your belts.
It's tighter, but you didn't have to remove the radiator.
Cool use of the camera.
Old Feb 23, 2012 | 04:40 PM
  #25
Teuf's Avatar
Ditto's on the seal.......
Old Feb 23, 2012 | 06:48 PM
  #26
James Woods's Avatar
Cool video, word of advice, don't ever become a mechanic you will starve on flate rate.
Blamalam
Mar 12, 2022 07:34 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
TJWilly
Jul 31, 2015 02:05 PM
yoterr
Jul 24, 2015 04:29 AM
