cost to have engine timed
Old Mar 30, 2009 | 05:55 AM
  #41
DupermanDave's Avatar
Originally Posted by Lumpy
You don't have to remove the plugs, if you never removed the dist you don't need to do that. I went the the advice from Thook and it's running fine. I have a bit of a valve tap but that could be another issue. If you do not like it at 5 make it 7. Listen to it run as well if it's too far it will tell you.
I know I can just check the distributor, but since I was unsuprtvised while assembling the head (and it was dark out) i want to be 100% sure I put it in right and everything is correct. So just to double check I wanted to remove the spark plug.
I also wanted to remove the plugs to see how they looked. See if I'm burning a major amount of oil or running the engine too rich.
Old Mar 30, 2009 | 06:05 AM
  #42
Lumpy's Avatar
Alright, I guess I missed the part that you had the head off. My bad. I'll go back to when I did mine. I had it all together and I was 1 tooth off, just a bit retarded and it would not run I had it floored it just barely idled, had a buddy trying to adjust the timing. Then took great care of slowly moving the dist out slowly until I felt it give, moved it 1 tooth and all was well.
Old Mar 31, 2009 | 12:17 PM
  #43
So I got the engine timed dead on. Yay! Wasn't that hard. I parked my truck in the darkest corner of the parking garage and warmed the thing up (i think I found a new permanent parking space, too :-) )
The darkness made the timing mark very easy to see. I was asking about using white out or something else to mark the belt or pulley because the mark was hard to see. But in this dark, dark corner it stood out.
So now I have it timed and we'll see how it drives :-) thanks for all the help.
While I was messing around under the truck, I noticed my exhaust pipe was splitting at a joint. It was bending and I'm guessing I now have an exhaust leak. But that's another issue that's going to be fixed in a few months.
Old Mar 31, 2009 | 04:20 PM
  #44
tc's Avatar
tc
Originally Posted by thook
I don't how far you live from any folks on this forum in CO.....like tc, lysmachia, etc. But, if they have a timing light, I'm sure they be willing to help you.
About 30 mins away (in Longmont, just off I25), and, yes, we help with stuff like this all the time. COTTORA has a TON of people right there in FoCo that would be willing to help too.
We can help fix that too.
Old Mar 31, 2009 | 08:19 PM
  #45
Ardent's Avatar
You're so nice TC. I wish you were closer to me.
Old Apr 1, 2009 | 05:12 AM
  #46
I'll have to refer to you guys sometime.
After timing the engine and test driving it, it hesitated a bit while accelerating. I unplugged the O2 sensor and the hesitation went away. Now I have an O2 issue.
But even with O2 plugged in and still unplugged, it idles really rough for about 20 seconds at a light. So now I'm lost again. Might end up replacing the whole engine.
Old Apr 4, 2009 | 05:24 AM
  #47
So it's almost been a week with the engine timed, and I now have an afterfire I've traced the cause to the engine timing. Since that's the only thing that's changed on my engine, I can only assume that's the cause.
After some research, I found out an afterfire is caused by unburned gases and hydrocarbons igniting in the exhaust. The cause is most likely a rich mixture.
Now is my mixture rich? Or just timed badly? Should I try retarding my timing, and if so, by how much? I timed it at 5 degrees TDC and 7 degrees TDC. I never had an afterfire when I timed the engine by ear, and it ran pretty nicely (idled rough)
Old Apr 4, 2009 | 08:55 AM
  #48
tc's Avatar
tc
I may have asked this already, but when did you last do spark plugs, cap, rotor, wires, etc?
5* BTDC is correct with the jumper and the tranny in neutral (if automatic), so it's time to move down the troublsehooting path. Timing won't fix everything. The engine will be a bit inclined to run rich here at altitude, but the O2 sensor and ECU should bring it back in after a while.
Thoughts:
TPS - http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Cat - is it plugged?
O2 sensor - when was it replaced last? It has to go REALLY bad before it will throw a CEL. Here's how to check it: http://personal.utulsa.edu/~nathan-b...42oxygense.pdf
ECU - let's hope not
Could have a dead cylinder that is pumping unburned gas into the exhaust. Possible causes:
- no spark (that's why I asked about cap/rotor/plugs/wires above)
- no compression (need to run a compression test)
Old Apr 4, 2009 | 09:03 AM
  #49
Justinlhc's Avatar
I would pull the plugs and if they all look the same and good, check compression. That will tell you everything you need to know.
If you don't know what you're looking for, post a picture of each plug(make sure you know which cylinder each plug came out of) and post the compression test results.
Old Apr 4, 2009 | 09:48 AM
  #50
Plumbrbob's Avatar
Originally Posted by spanish-road
I do it by ear and so far Im dead on.
The steps:
one: remove the #1 spark plug and take it out of gear set the parking brake
two: place finger in the #1 hole rotate crank shaft with a socket or special tool, i use a tire tool from a mazda 323
three: rotate tell you get a wosh sound that wants to blow your finger off.
four: do it again to be sure
five: set to 5* before top dead center
six: remove dizzy and cap rotate tell you get it pointing to #1. On the gear end it has tow
notches match them up.
seven: insert very carefully!
eight: adjust tell you have the star point lining up with the little strip of metal at the
bottom front side.
nine: put it back together and remove the socket!
ten: fine adjustment and take to a dealer if your unsure of what you have done...
I can do this in my sleep and i do it just for kicks.
This is how I do it as well and I use a vaccuum timing gauge to fine tune my distrubutor adjustments. I have used my timing light in the past but after extensive modifications to my engine the factory settings no longer apply, in fact if i set my motor to factory settings it will run like a deisel or not run at all.
Old Apr 4, 2009 | 09:59 AM
  #51
spanish-road's Avatar
Well today was a failed attempt. I got the timing light and verified it works. I hooked it up to spark plug wire #1 and did get it to flash...remove the spark plugs...
um, why? that is if your starting out with a new messed up dizzy so that you can get everything aligned right.
Are you sure your doing it right #1 is right at the front of the engine. I could go take pictures cause im doing it today. i just got a new light and tachometer! I had to replace my old one cause it is 2300 miles away from me.
the way i did it at first is that i had old huge engines to learn on. think basic, mason jar basic with a tp roll as a oil filter.
EDIT: that diesel sound it the Toyota signature, its their way of saying they love you.
Old Apr 4, 2009 | 10:11 AM
  #52
gosh i wish i had a basic no computer running anything engine, just a carb, vacuum advanced dizzy, then the sure basic.
Old Apr 4, 2009 | 10:28 AM
  #53
plugs, rotor and wires were all replaced about 6000 miles ago during the head gasket job. I did a compression test on each cylinder a while back and got about 160 psi per cylinder. I checked each plug wire and pulled to test each cylinder and see if i could fine a dead cylinder. They all seem good, as are the injector wires. I may change the plugs just for the heck of it. o2 sensor are unplugged for testing and theyre due to be replaced in a week or two. why would the rotation of the distributor affect o2 sensors?
Old Apr 4, 2009 | 11:01 AM
  #54
it advances and retards the sparking time. So a sooner spark or later one.
Old Apr 4, 2009 | 11:15 AM
  #55
Justinlhc's Avatar
Well checking the plugs and doing a compression check 6000 miles ago doesn't really do you much good right now. The o2 sensors being unplugged.....ummm.....don't ya think that could be a problem????????????
Old Apr 4, 2009 | 11:46 AM
  #56
the plugs and wires were done a rough estimated 6000 miles ago. i checked the plugs and did a compression test about not even 1500 miles ago. And i just last night unplugged the o2 sensor to give me back my horsepower and keep it from being sluggish. Its still afterfiring though, but its doing it a whole lot less now that theyre unplugged
Old Apr 4, 2009 | 11:58 AM
  #57
Justinlhc's Avatar
Spark plugs constantly change. Even if you checked them 15 miles ago that still doesn't tell you what's going on right now. When we tune motorcycles we run the motor at the desired range that needs tuning adjustments and kill the motor, check the plugs and go from there.
You don't seem to want to look into any of the obvious solutions. That's not going to get anything fixed. Why not check and re-check everything to make sure it's CURRENTLY operating properly. You can't just rule everything out as a possible problem because it was working properly a while ago. I've installed brand new parts that were defective plenty of times. If I would have ruled out the brand new part as being a problem simply because it was new I would have never figured out the problem.
Good luck.
Old Apr 4, 2009 | 12:19 PM
  #58
Good luck.
ill be checking some of the obvious stuff when i can. I dont have a lot of the tools to do it right now which is why it has to wait until payday. my spark plug socket and a few of my other tools disappeared
Old Apr 4, 2009 | 12:22 PM
  #59
tc's Avatar
tc
You can throw parts at it, or you can go through a systematic diagnosis and find out the real problem and fix it, or you can band-aid it together and get it to run for a little while, then be fighting it again.
X1000000
Got enough $ for gas down to Longmont? The offer was made several times to help you out...
Old Apr 4, 2009 | 01:56 PM
  #60
X1000000
Thanks for the offer. I just don't want to feel like a mooch is all. If the o2 sensors doesn't fix it, we could possibly meet up to check it out.
by "disappeared" i mean i left a few under the hood and drove off.
I'm ordering the o2 sensor and buying some new plugs (and plug socket) and seeing if that changed anything. If that fails, what else should I look for? Could the TPS be an issue, even though I just adjusted it? Malfunctioning?
