Coolant System Leak? Among other issues...
Old Feb 28, 2011 | 04:23 PM
ashdub01's Avatar
Hey everyone...First let me introduce myself...I'm new here and my name is Ashley. I have been on other 4Runner forums and wasn't even acknowledged
So I decided to try to get some help here...
Long story short my mom fell in love with a 95 4runner 3.0L, which she has had for almost a year and has been unable to smog. We've had Toyota check it out 4 times ($155 per check) and each time they were able to get the Check Engine light off for a short period of time, until we gave up with them.
We've since taken it to several different smog shops and were told each time that whatever is causing the 4runner to not pass smog is minor, one shop told us to do an oil change and change spark plugs and wires. Did that, went back a week later and....it still won't pass.
Bought "Guaranteed to Pass" and poured it into the gas tank as it says to do, still won't pass.
Anyways....The very last time we were at a smog shop, 2 weeks ago the printout he gave me says "Coolant System Leak" I don't even know what that means?
I have it up for sale now but would hate to sell it if it's something that can be fixed without burning a hole in my pocket...
Any help is appreciated
Old Feb 28, 2011 | 04:25 PM
874runnersr5's Avatar
what are the readings from the smog tests?
Old Feb 28, 2011 | 04:28 PM
ashdub01's Avatar
Only one shop gave me a paper and thats the one that says Coolant Leak, the other shops just told me 4 codes... which weren't written down so I have no clue what they are now.
Old Feb 28, 2011 | 04:53 PM
swampfox's Avatar
Is there any coolant loss ? This might indicate a head gasket problem that could cause the failed test. And by the way welcome.
Old Feb 28, 2011 | 05:06 PM
ashdub01's Avatar
I haven't noticed any coolant loss, I thought that code was wierd.
Old Feb 28, 2011 | 05:43 PM
chad450r's Avatar
I'm on my phone pardon my asking if it in your bio. What year ? What motor? Have you checked for codes? Does it blow white smoke? Oil milky white? Again coolant low? More info makes it easier to help!!
Old Feb 28, 2011 | 05:51 PM
4Crawler's Avatar
It is easy enough to pull and clear the check engine codes:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Might have the shop that told you about the coolant leak point it out to you.
Old Mar 4, 2011 | 11:23 AM
ashdub01's Avatar
Sorry, it's a 95 3.0 V6
no coolant change,
It does have white smoke when starting up but goes away...
I noticed oil leaking from the seal yesterday...I just happen to have a brand new seal Toyota accidentally gave me...once I switch them out I will decide from there..
Also, I can clear the check engine light but once I take it in to have it smogged it turns on once they have the car on long enough.
Old Mar 4, 2011 | 11:47 AM
chad450r's Avatar
What is the code?
no coolant change,
If you can count the blinks to get the code it might help point you in the correct direction
jasonty
41
Dec 23, 2018 01:00 PM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Avenged
Jul 9, 2015 07:55 AM
