Coolant System Help Needed
Old Jun 23, 2005 | 03:17 PM
waskillywabbit's Avatar
I noticed my water temp gauge spiking about 5 minutes after initial startup. It goes up about 3/4 of the way, never gets redlined, but gets hotter than normal, and then goes back down to normal, which is a little less than halfway. It did it this morning and on the way home from work, both the same each time. Once it spikes, runs fine after that with no issues.
I recently pulled the heater core (all the HVAC) and the hoses and rerouted the return line to the feed line right before where it used to go into the heater core. I'll clean all that up later.
Here are some possible causes/solutions:
air pocket in coolant system from removing hoses/heater core and low on coolatn - I checked it and it is full so it will work itself out
t-stat sticking - r/r
t-stat sticking because of debris in system - flush system
Any diagnosis and advice is appreciated.
Old Jun 23, 2005 | 06:15 PM
Bump
Old Jun 23, 2005 | 06:24 PM
Steveh29's Avatar
That to me sounds like a t-stat. I say that because it spikes then corrects itself. Behaves like the t-stat is either sticking closed or somehow having trouble opening. Once it opens, the system cools properly. Just my thoughts.
Old Jun 23, 2005 | 06:38 PM
jimbo74's Avatar
do the dual stage t-stat
www.4crawler.com
Old Jun 23, 2005 | 06:51 PM
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
This sounds exactly what mine is doing...but it only started doing it AFTER I removed the heater core and looped the system. Hmmmm...
Old Jun 23, 2005 | 06:58 PM
Steveh29's Avatar
I'm not familiar with the 22RE cooling routing, but could the looping of the system be causing the coolant to flow fast through the heater core loop and put some sort of pressure on the t-stat which holds it closed. Finally the system builds up pressure though heat and blows the t-stat open? Just taking a wild guess here.
Old Jun 24, 2005 | 05:50 PM
I'm going to cap off the feed/return lines by blinding off one side and taking the other side off, cutting it past the sensor nipple and welding it up. Then no more loop. If that doesn't fix the t-stat issue, then I'll put in the 2 valve t-stat and I'll have no more loop anyway...as I don't need it w/ no heater. Just something else to leak.
Old Jun 25, 2005 | 01:52 PM
4Crawler's Avatar
The cooling system is *very* sensitive to this "problem" from what I have observed. Mine used to be fine, then I made some small change and the problem showed up. Since installing the 2-valve t-stat, has never showed up again. The new t-stat is a superior design to the original 1-valve unit, it works very good, maintains a much more stable temperature and lasts a *long* time. Smaller slugs on the two t-stat valves respond to temp changes much faster than the single large slug and you get a built-in redundancy with the two valves.
Old Jun 30, 2005 | 06:53 PM
Bigblock's Avatar
where do you get these 2 valve t-stats?
Old Jun 30, 2005 | 06:54 PM
Part # of 4Crawler's website above. At the dealer.
Old Jun 30, 2005 | 07:25 PM
jimbo74's Avatar
yeah they jacked up the price though... its now like $38
it works awesoem though... enver had any issues since i put mine in...
the stock tstat i had before i put in the 2 stage was only 3 months old before it failed!
Old Jun 30, 2005 | 09:17 PM
4Crawler's Avatar
Yep, dealer parts counter is where I got mine:
I've had mine in 6-7 years now, still going strong. I did pick up a spare a few years back, but have not needed to install it.
Old Jun 30, 2005 | 11:54 PM
wimpywade94's Avatar
Mine is doing the excact same thing right now. the only thing i have touched on the cooling system is the throttle body part, I took it off to clean it and lost a little coolant.
dual thermo is on the list of things to do now!
wade
Old Jul 7, 2005 | 01:45 PM
Don't ask me why, but since I took out the heater loop completely...all that stuff...and just ran a 6" hose from the intake to the return it doesn't spike anymore.
If it acts up again, or I have to replace it, I'll got to the new 2-valve t-stat.
BigArt70
Jun 30, 2015 09:51 PM
LSUMatt1514
60
Oct 10, 2003 12:30 PM
jalaber
Jul 24, 2002 06:48 AM
HALMAN
Jun 14, 2002 09:02 PM
