coolant problem
Old Sep 19, 2012 | 08:06 AM
scot's Avatar
coolant problem
Can anybody explain to me why I would have coolant in the air filter box of my '89 V6 3.0.
Old Sep 19, 2012 | 10:39 AM
scot's Avatar
OK. Could the auxiliary air valve be in a stuck open position? If so should I replace the entire TB unit?
Old Sep 19, 2012 | 01:49 PM
MudHippy's Avatar
I'm not sure about it being stuck in any position. But it probably would be where the coolant is coming from. If it was stuck open you'd have a high idle condition while the engine is hot/warm. So you tell me...is it possibly stuck open? Though, if it's leaking coolant into the intake, I'd say it doesn't really matter at this point if it is or isn't stuck open(or closed, or in between). IOW, the valve's functionality is pretty irrelevant to the current situation(makes no difference one way or the other if the valve's not opening/closing properly, because if it's leaking coolant internally, it's most likely damaged beyond repair and needs replaced anyway).
So, as far as what to do if the AAV is leaking coolant internally. Yes, replacing the entire TB is most likely all you can do to fix that. Since the AAV is not serviceable on its own(no replacement parts or specs available).
Old Sep 19, 2012 | 03:17 PM
scot's Avatar
Thanks for the help MudHippy.
the1998sr5
15
Jul 14, 2020 08:35 PM
skoti89
Sep 11, 2015 07:46 AM
Logz808
Jul 26, 2015 07:09 AM
jjrbus
Jul 23, 2015 05:05 PM
Poncho0206
Jul 10, 2015 06:21 PM
