Coolant noise, help
Old May 4, 2008 | 03:00 PM
TORTIS's Avatar
sounds like you have a leak somewhere. are you losing fluid? my old 4runner had the same problem, and it turned out to be a very small, and when i say small, i mean small leak in the cooling coils of the radiator. the coolant was evaporating before it could reach the bottom and drip. i would take a while before the coolant would get low.
Old May 11, 2008 | 10:56 AM
Jay351's Avatar
Gonna bump this topic back up.
Yes, I have 3 microscopic leaks at the top of my rad, every few days there will be a bead of coolant at each hole.
Other then that I am not losing any coolant at all. Thats how I know it can't be a hg.
and now, its getting worse. I can hear it if I turn the heater to cold but its not very loud.
Im hoping to find a used rad asap, I can't afford a new one.
Old May 11, 2008 | 08:08 PM
LotOMiles's Avatar
Originally Posted by crowley84
Jay351,
I have a similar situation but I have a 22re with a slight coolant leak from one of the small hoses underneath the intake. When I start it up in the morning, if i slide the heater control from cold to hot, I hear a slight water "gurgle/rush" from the heater core. I've bled the system but I assume that I have air getting in the system from the small leak. I don't have a head gasket issue and once the truck is warmed up - no noise.
My 3.0 does the same thing. The gurgle only last a second or so. The coolant level has not gone down and I have no other problems.
jashoeuh
Nov 18, 2024 08:08 AM
norcal98
Aug 10, 2015 06:20 AM
genuinegemini
Aug 3, 2015 04:56 PM
razorman8669
Jul 12, 2015 12:13 PM
Poncho0206
Jul 10, 2015 06:21 PM
