coolant leak, water pump pulley
Old Nov 12, 2012 | 09:24 AM
element138's Avatar
well, I got it back together and torqued. It's running and sounds smoother than ever...
PROBLEM!
coolant is leaking into the timing chain chamber (presumably from one of the coolant passages) I cleaned the living hell out of the block and timing chain cover surfaces and used brand new timing chain cover gaskets from the dealership. I don't understand where this leak is coming from? anyone have similar experience with this issue? I'm pressure testing the coolant system here in a minute to see if there is in fact a leak. or if, perhaps, the coolant in the oil is residual from pulling the TC cover off. (last time I pulled the oil pan out, there was 6-10 oz. of oil remaining in the bottom of the oil pan, even with the plug pulled.) so It's possible that the coolant dumped down when I removed the TC cover.
holy hell...
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
TammyMarie
Jul 15, 2015 11:14 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
