Coolant gauge never gets to temp and heater doesn't work
Old Nov 19, 2013 | 02:45 PM
starko357's Avatar
Hi, I've got a 1986 Toyota 4x4 with a heater problem. I've felt the heater hoses and one of them is definitely warmer than the other. The heater does blow some heat, but its very minimal. I think the heater core is probably blocked up, but the coolant temperature gauge never gets to operating temperature. Could this be the result of a stuck open thermostat? I think its probably an issue with the temperature gauge or coolant temp sender and heater core, but I don't want to go through the work of tearing out the heater core if it could be an easier fix. The truck runs great other than this, any advice is greatly appreciated, thanks!
Old Nov 19, 2013 | 02:58 PM
SPARKS89's Avatar
Pull your thermostat and boil it in some water on the stove to check for function. If you have a thermometer you can stick in the water, use that to make sure the thermostat is opening at the right temperature. Just remember don't let it sit on the metal bottom of the stove. The metal will transfer the heat directly to the metal on the thermostat and give you an inaccurate reading. Suspend it with a string or set it on a plastic something-or-other on the bottom.
It sounds like you have a problem with your heater core. You'll have to look into that.
Old Nov 19, 2013 | 03:28 PM
Discombobulated's Avatar
Was any stop leak ever used?
Old Nov 19, 2013 | 03:34 PM
LITLRED's Avatar
Check to see if the heater valve on the firewall is functioning properly.
Old Nov 19, 2013 | 03:37 PM
Bullet22r's Avatar
I have the same issue but my my heater works perfectly fine and the temp gauge is about 1/4 way up when running normal.
Old Nov 19, 2013 | 04:49 PM
SoCal4Running's Avatar
I've had 2 Toyota trucks (84 pickup and my current 86 4Runner) that the dash gauges on both never read correctly. I replaced all 3 coolant sensors on both trucks but the gauge would jump from all the way down to over heating in a flash. If it registering half way up after about 5 minuets warm up hen its operating fine, but should not just jump up there.
If your thermostat is stuck open or missing all together your engine either run very hot or never warm up depending on your radiator...
Old Nov 20, 2013 | 09:43 AM
starko357's Avatar
Thanks everyone for the responses, the radiator hoses definitely get warm, but the coolant gauge doesn't rise at all. (should've clarified that in the post) I recently bought the truck, so I have no idea if stop-leak was every used in the coolant. I'm gonna try and work on it a little today, if the coolant gauge doesn't rise at all, even if I drive it for an hour, it must be the gauge or the sender right?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Avenged
Jul 9, 2015 07:55 AM
