Compression test numbers
Old Apr 9, 2010 | 09:40 PM
Toyo4x4's Avatar
I had a CT done today and here are the #s:
1 - 199
2 - 198
3 - 199
4 - 201
5 - 200
6 - 201
I haven't had a chance to talk to my mechanic and I've read that normal is ~171.
Head gaskets were done @ 60K and I now have 184K.
Are these #s too high? Carbon build-up in the combustion chamber?
Just wanted to see what you guys thought.
Thank you!
Old Apr 9, 2010 | 09:47 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
good god today....
heads milled just a smidgen?
Old Apr 10, 2010 | 05:48 AM
yayfortrees's Avatar
tried makes a great point. Do you know if the heads have been milled?
I wouldn't worry about it much, unless it's not running good. I can't imagine carbon building up so perfectly across all the cylinders, that the compression is so close.
What octane gas do you normally run? I would be running premium or midgrade at the least with 200 PSI compression.
Old Apr 10, 2010 | 06:05 AM
James Dean's Avatar
Nothing wrond with high compression if they are all that close to each other. You may have to run a higher grade octane to keep in from pinging. There is also the possiblity that the gauge you used isn't calibrated correct. Either way the important thing is that all the cilynders are close to the same.
Old Apr 10, 2010 | 09:36 AM
I also wouldn't count on that engine being non interference anymore
Old Apr 10, 2010 | 09:49 AM
Toyo4x4's Avatar
I believe the heads were milled...60K was a long time ago.
No pinging...use 87. And the truck is running well.
Yeah it makes sense that it wouldn't be carbon with the numbers so close...good point.
Old Apr 10, 2010 | 12:04 PM
rattlewagon's Avatar
it it isnt broken, dont fix it.
Old Apr 11, 2010 | 09:09 AM
bone collector's Avatar
x2
so if the truck is running well... why the compression test?? just curious
Blamalam
Mar 12, 2022 07:34 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
84'22r
Feb 13, 2019 05:35 AM
the1998sr5
27
Nov 17, 2015 09:30 AM
Sidherish
Aug 2, 2015 01:42 PM
