Compatible vsv's for 3.4 conversion
Old Oct 22, 2006 | 01:40 AM
Bajatoy's Avatar
Not sure this is in the right area but here we go!
Long story short, have a super charged 3.4 from a 2001 tacoma 5 spd. A wire harness and complete conversion kit from offroad solutions from a 2003 2wd 5 spd tundra and it is all going into a 94 pickup. Got the wire harness from a salvage yard in california and they did not send the vsv's. Called them up and they dont even know what they are or what they look like... Told them that they should be on the pass side fire wall but they cant find them. Tried calling toyota because I figured would just get them new, they said they cant tell what kind where there unless I have the origional #'s off the vsv's.
Does any body know if there are any vsv's that are compatible or have any ideas how I can find out what the #'s off the origional ones where?
Old Oct 22, 2006 | 06:52 AM
mudbutt's Avatar
The ones on the drivers fenderwell are for the evap emissions. You need a Purge VSV, pressure switching VSV and a Vapor pressure sensor. The Pressure VSV and pressure snnsore are mounted to the charcoal canister and come with it if you buy it from toyota. The purge VSV is mounted close to the canister on a rubber isolater.
The pressure switching vsv that I have is part #90910-12130
The purge and pressure sensor didn't have part numbers that I could see. The purge vsv sould have one but my donor truck had some overspray from a bad paint job.
Brian
Old Oct 22, 2006 | 07:16 AM
Bajatoy's Avatar
So all I need is 3 of them. I will call toyota and see if they can help me any with that information.
Thanks
Old Oct 22, 2006 | 07:25 AM
mudbutt's Avatar
You might be missing some other stuff, I have not seen a Califorina emmision Tundra v6 here in colorado. I'm not completly familar with what extra componets they have.
Old Oct 29, 2006 | 12:08 AM
Bajatoy's Avatar
Well, I have had no luck trying to get the salvage yard to find them and the guys at the toyota dealership still are not willing to be helpful in any way or form. Any body have anyother thoughts?
Old Oct 29, 2006 | 07:34 AM
mt_goat's Avatar
Try another dealer, that doesn't sound right that you can't at least get them new from a dealer. If you don't have a VIN # for your engine/ECU combo try to find a similar truck and use that VIN #. Two of the evap parts are probably going to come screwed onto the 3.4 evap canister and the other is mounted on the firewall.
justdifferentials
14
Jun 11, 2017 08:36 PM
runnermedic
13
Sep 21, 2015 05:20 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
dlaiben
3.4 Swaps
Sep 3, 2015 09:57 AM
