Clutch will not fully disengage.. hElP...
Old Oct 29, 2008 | 07:26 PM
88'Black-sub's Avatar
Arrow Clutch will not fully disengage.. hElP...
so i got my 5 speed swap done tonight. and my clutch will not fully disengage. and i was wonedering if it would be cause i got the slave cylinder out of a 4 cylinder 4-runner and mine is a v6. and when i got the slave it did not move at all and i worked it untill it did.
Old Oct 29, 2008 | 07:35 PM
jason191918's Avatar
1. Is the res full?
2. Did you bleed the system?
3. Can you see the slave moving?
4. When you push the pedal in, does the clutch slip or do nothing?
If it does nothing, it could be a seized pilot bearing. Did you check it?
Old Oct 29, 2008 | 07:40 PM
yea me and my dad blead it and the fork moves but only like a quarter or a little more of an inch
Old Oct 29, 2008 | 07:42 PM
Scooby098's Avatar
you could have a bad slave there only like 20 buck you can get a whole clutch system for around 35
Old Oct 29, 2008 | 07:44 PM
my master is brand new. but the slave is old.. so hopefully its somethin simple like that. instead of something gone wrong when i put the tranny in
Old Oct 29, 2008 | 11:39 PM
drew303's Avatar
Your pedal could need adjusting. If the pedal isnt pushing the piston rod in on the MC far enough your not moving the piston rod on the slave out far enough to move the fork IN enough... phew. lol
If you replace the slave, I reccomend OEM. This is more important if your replacing the MC .. for some effed up common reason.. the aftermarket masters tend to end up leaking, or at the very least squeaking (ugh) . true story.
Goodluck
Old Oct 30, 2008 | 11:51 AM
i just bought my new slave today with lifetime warrenty for 11 bucks. hopefully it fixes the prob but ill check into adjusting the pedal.. thanx
camel_65@hotmail.com
Oct 3, 2018 06:11 AM
sonorn67
Sep 19, 2015 05:39 PM
93toyoguy
3.4 Swaps
10
Sep 18, 2015 04:16 PM
Corvoid
Sep 14, 2015 10:10 AM
