clutch replacement
Old Aug 14, 2010 | 05:56 PM
  #101
1990yota-pickup's Avatar
take pictures next time dave.. dont get all in a rush next time... slow dont smoke aciggerate an take a fe pictures for scrap book and picture book assembly for next time.. good luck...
Old Aug 14, 2010 | 07:38 PM
  #102
rustypigeon's Avatar
Originally Posted by DupermanDave
But just to confirm, the skinny end points towards the front?
Yes. Skinny end forward.
Old Aug 14, 2010 | 07:41 PM
  #103
SoCal4Running's Avatar
The picture is 100% correct, the CV joint is closest to the transfer case. Good news you got it back together
Old Aug 14, 2010 | 08:49 PM
  #104
PismoJoe's Avatar
A happy ending!! Nice work!
Old Aug 15, 2010 | 06:17 AM
  #105
DupermanDave's Avatar
Possibly happy ending. I won't consider it a happy engine until the truck is started and I'm able to drive away. 3 times now have I thought I finished a project and found out after I put everything together that I either broke something else in the process or installed something incorrectly.
Old Aug 15, 2010 | 06:29 AM
  #106
hey, dave its just a learning curve.. ya gotta start some where..
Old Aug 15, 2010 | 07:59 AM
  #107
I know. It's not like I'm depressed about it, but I've just learned not to get my hopes up until it's on the road and doing a test drive.
Old Aug 15, 2010 | 10:08 AM
  #108
now your talking like you go to the bar.. and are too afriad of picking up wemon..
man up and get you head in the game, foot ball season has started...
your going to need that truck, for football tailgate parties...
Old Aug 15, 2010 | 04:14 PM
  #109
Everything is back together now. Transmission is up, shifters are in, the slave cylinder is in place, drive shafts are all bolted up...and now when I go to try and put the truck into a gear it won't. When the engine is off I can freely move through the different gears with no clutch pedal, but once the truck has been started the clutch doesn't want to let me change gears.
I checked my chilton manual for any sort of clutch adjustment procedures and all I could find were clutch pedal adjustment.
What else can I look into to try and remedy this? I didn't mess with any brake/clutch fluid, and I highly doubt the system got air in it, but could the slave cylinder need bled?
-edit-
so here's what we know:
the truck will start while in gear when pushing the clutch pedal down. You can go out of gear (really hard) but cannot go back into a gear.
With the truck still in 3rd and the engine off, if you try and start it in gear the truck will lurch forward.
I started the truck with the pedal all the way down in 3rd gear and very very slowly let it up to see where it would want to stall and even with the slightest budge of letting the pedal out it wanted to stall.
We bled the fluid system and it did nothing for it. Now I'm looking for a way to adjust the clutch pedal/master cylinder.
Old Aug 15, 2010 | 08:36 PM
  #110
We got it figured out. We adjusted the clutch/master cylinder and it disengages properly now.
Now I have other issues, where are detailed here: https://www.yotatech.com/forums/f116.../#post51526268
Thanks for all of the help and feedback. It's greatly appreciated. Now for some sleep.
Old Aug 16, 2010 | 02:06 PM
  #111
good job dave... thats away to hangin in there.. while times got tough...
Old Aug 16, 2010 | 02:32 PM
  #112
I'm now dealing with what I fear may be an even worse issue. It won't idle high enough to not stall, and there's so many things that can affect that I don't know where to begin. At least with the clutch I was able to take it one step at a time and I knew where the problems are/were.
Old Aug 16, 2010 | 03:17 PM
  #113
do u got pictures of your engine so we can look at it to see what maybe be the issue..
Old Aug 16, 2010 | 03:41 PM
  #114
I can get pics (high resolution pics) of the engine, intake, and vacuum hoses so you can get a feel for what may be going on. But I'll post everything here: https://www.yotatech.com/forums/f116...rnator-218221/ to keep yotatech more organized.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
