clutch release cylinder
Old Oct 25, 2010 | 12:24 PM
angrydogtattoo's Avatar
When I replaced the clutch in my 83, I tried the grease trick, by filling the pilot bearing hole with grease and then putting in a socket that just fit and then tapped that home, the out come would probably be the same regardless if I had used wet paper but instead of the bearing coming out, the outer side of the bearing came off, leaving me nothing to really push against.
I made a cheap puller out of a C-Clamp!
I had a very cheap 3" C-Clamp that I removed the screw from I placed a nut on screw the same size of the C-part of the clamp and then using the new pilot bearing as a guide bent a hook into it, I then put that through the hole of a large socket and hooked the old bearing and used the nut to apply force to the socket and "pull" the bearing out, at first I didn't think it was going to work but all at once it just popped out.
Sep 4, 2015 09:27 AM
Iceman4193
Aug 28, 2015 08:43 PM
bfmcelroy
Aug 18, 2015 06:42 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
