Clutch master cylinder
Ok i put a new one in my 86 turbo 4runner. I went to bleed it and nothing..... No pedal whatsoever. I pumped it over 100 times and it didn't build pressure at all. Whats up with it?
kthxbye
kthxbye
x2, is the bleeder valve open at the slave cyl? If its closed and your still not building pressure check the fluid lines into the master cylinder and into the slave cylinder. Then check the seal on the new master cylinder and make sure its not bad right out of the box. If all that is good and you are still getting no fluid pressure check if you are loosing any fluid at all. If so check out the hardlines and softlines completely and figure it out. Why did you replace the MC in the first place? are you sure it wasnt really an issue with the slave cylinder instead?
"pete f passed away quietly in his sleep on July 13, 2008
I gravity bled mine. open the bleeder at the slave and let it slow drip for an hour close the bleeder and your good to go.
gravity bleed
It worked really good for me on clutch and front brakes.
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
