clutch issues
Old Aug 28, 2011 | 06:51 AM
s.resko's Avatar
clutch issues
hey all! i just replaced my hydrolocked 3vz for another one with less miles but after i got everything bolted back together the clutch doesnt fully engage so its extremely hard to shift, and damn near impossible to put in reverse. i already adjusted the pedal as far as it would go and bled the clutch once and it helped a little but it still does not fully engage
Old Aug 28, 2011 | 06:52 AM
s.resko's Avatar
any thoughts of a possible problem/solution?
Old Aug 28, 2011 | 10:01 AM
evileyejones's Avatar
new master and slave cylinder?
its a pretty basic system, it only has master cylinder, reservoir, metal lines, and slave cylinder. if one has a leak or worn seals they all don't work right. if one cylinder goes bad, the other will most likely go bad within a few months of replacing the worn one.
also, they are cheap, 10-15 each.
Old Aug 28, 2011 | 10:25 AM
s.resko's Avatar
that may be a good solution, just perplexed cuz everything worked fine before i pulled the engine but it sat for about 2 months before the new powerplant so ill try that, thanks!
Old Aug 29, 2011 | 03:49 AM
TNRabbit's Avatar
If it's that hard to push, something is binding. Are you sure you got the clutch aligned properly?
jasonty
41
Dec 23, 2018 01:00 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
