clutch install ?s
Old Feb 19, 2007 | 04:11 PM
hektikwon's Avatar
clutch install ?s
I installed my clutch about a month ago and was a little confused on the way the disk went. I believe the side with the springs sticking out the farthest was facing the tranny. Now I'm replacing one on a 2000 and it looks like the old clutch has the side with the springs sticking out facing the flywheel. I'm a little confused as to which is the proper way. Neither disc look as if they have any markings as far as directions. Also what will happen if the disc is backwards?
Old Feb 19, 2007 | 04:16 PM
rezrunner92's Avatar
you won't be able to get everything bolted up correctly.
Old Feb 19, 2007 | 04:17 PM
Dan_90SR5's Avatar
Generally the side of the clutch disc with the shaft sticking out faces the tranny. The flattest side (when considering the entire face) mounts facing the flywheel.
In other words, you had it right the first time.
bballchrism's Avatar
well on my dads old runer we installed the clutch backwads there was alot of sliping and everytime you changed gears the would sound like the grinding
thats what think it was along time ago
Old Feb 19, 2007 | 04:21 PM
Targetnut's Avatar
yes they will make a lot of racket if installed backwards.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
